Results 1 to 6 of 6
    Hi!
    Baka alam nila kung ano sira pag sinasagad yung steering wheel namamatay yung makina.
    Thanks!
    Francis
    Apr 2009
    Ewan ko lang sir, no expert here pero baka sa electrical contact sa ignition starter mo (sa may bandang susian) may tumatama pag sagad na sa kabig yung manibela.
    Sakin dati pag sinagad naman tumutunog yung busina, sa wiring kasi eh.
    Di ko lang po sure .. wait natin sila.
    *francismec
    What's the make and model of your car? Kung sinasagad yung steering wheel sa dulo at pinilit pa din i-turn, malaki ang stress na nangyayari sa power steering pump. Bumibigat yung pump, and since may fan belt na nakakabit sa pump at crank ng makina, natatransfer yung stress na iyon sa idling.
    Hi!
    Nissan 98 Series 4 yung car ko na pagsinagad yung steering wheel namamatayan ng makina. May prob po ba sa idling ko? Thanks sa ideas. SA may mga alam regarding this problem pa post na lang din para madami me ideas.
    Thanks!
    Francis
    If your car idles around 800rpm and stays there regardless if you have your aircon turned on or off, then the idle speed is not the problem. Most likely its in your steering system.
    Let's wait for the others to post their comments.
    Dec 2010
    It's a fairly rare problem but it happens; the engine stalls as you turn the wheel. It happens during turning or when reaching the limit either way, sometimes during maneuvering the car in reverse (strange). If the stalling doesn't occur when other loads are applied like turning the A/C on or shifting into gears, then you've narrowed it down to the steering system. We had that problem in the shop before on a Sentra and an Audi. The symptom was further characterized by a marked erratic stiffness while turning. Both were solved by replacing the steering pump and the feed hose.
Streering problem? Engine loss
