Results 1 to 8 of 8
    Nov 2006
    i hear that tsk tsk tsk when driving my 99 honda city type z sound especially on asphalted road. all tires are relatively thick about 90%. kinapa ko na isa-isa at di naman oblong. what could be the problem? wheel balanced last may 2010...
    Have your brakes checked, it may be dragging.
    Are you sure the sound comes from the wheels and not from the engine compartment? It may be a loose fan belt.
    Jul 2003
    inspect all tyres. it could be an inside ply of the tyres that is damaged. Try to find and locate which of the tyre is causing this sound. Then have it removed
    from the wheel to check the inside ply.
    Nov 2007
    could be wheel bearing ganyan din nangyari sa oto ko
    Dec 2010
    Wheel bearing noise is a continuous humming sound that goes faster and louder as the accelerates from about 40kph and abates as you slow down. Wheel balancing is if you're experiencing steering wheel wiggle at about 60kph and up and disappears at about 80 or 90kph.
    Its probably the tires. Kahit na mukhang makapal pa, sometimes they cause that kind of noise. Now, if you're noticing the noise from the front and the car pulls to either side, the tire from the side where it pulls is defective. Steel belts inside are torn and separated causing it to bulge, pull to a side and become noisy. Delikado yan. It's the main reason for tire blow-ups.
    Nov 2003
    check the brake rotors. baka sumasabit sa pad or backing plate.
    Dec 2010
    ..or maybe the pad spring clips are bent and touching the rotors.
    Nov 2006
    id say it's more on tire defects. looks thick but probably invisibly oblong somewhere. though no problem with steering, no grabbing...
tsk tsk tsk sound
