Results 1 to 9 of 9
- Sep 2003
- 81
January 17th, 2004 11:32 AM #1Good morning diesel gurus!
Question lang po ako mga sir about steering wiggle, pag tumatakbo po ako between 80-100 nagwiwiggle yung steering tapos may parang tunog sa gulong. Na try ko na po pa wheel balance saka napag rotate ko na din (medyo hindi pantay kain dun sa gulong) Nung pinacheck ko po sabi ng mekaniko ko kailangan na daw palitan yung 2 lower ball joint after daw nun pa wheel allign ko na daw.
What do you guys think?
thanks
January 17th, 2004 11:35 AM #2
Ball joints & tie rod ends have to be checked. Btw, ano bang ride ang pinaguusapan natin? :D
January 17th, 2004 11:40 AM #3
ser..pag po ba lumalapmas kayo ng 100 eh nawawala din ang wiggle?
check niyo din baka may BUKOL na ang isa sa mga gulong niyo.
ganyan ako dati.palit na lahat ng pang ilalim nandun parin wiggle.un pala gulong.pakshet
- Sep 2003
- 81
January 17th, 2004 11:48 AM #4thanks po sa mga reply sir glennster and sir ungas
adventure po, meron na din po bukol, tapos pag lagpas po ng 90 medyo humihina pero hindi pa rin nawawala parang nakakatakot na nga eh, saka parang maririnig mo yung tunog sa labas ng gulong pag sa passenger side.
January 17th, 2004 12:41 PM #5
SImple lang po ang problema niyo.
If the steering wheel wiggle ONLY appears at speeds of 80kph and above, all you have to do is have the front wheels balanced.
sure ball yan.
Yung mga minention nila, that's for wiggles which happen at speeds even below 80.
January 17th, 2004 12:47 PM #6
Don't forget to have your suspension components checked too...
1. ball joints
2. tie rod ends
3. rack ends
4. idler arm
5. center link
6. steering shaft
- Sep 2003
- 81
January 17th, 2004 02:14 PM #7Ah ok thanks a lot mga sir :D Isa na lang po, san po kayang shop maganda mag pa check ng suspension?
- Sep 2003
- 81
this is my biggest complain with EVs... the whole vehicle will be disposed later. no one wants...
All New Toyota Corolla Cross
