Results 1 to 20 of 21
    Jan 2019
    Hmmm...
    1. Wheel Balancing - makikita mo na din kung sira yung RIM, kung magaling yung gagawa, baka makita nya din kung oblong yung gulong.
    2. Sine tanggal na parehong gulong, makikita mo na kung masama na yung tie rod end, or kung may leak yung power steering
    3. Rotors - kapag nag shake sya while stepping on the brakes.
    Noted. Thanks. Mga prices kaya
    Jan 2019
    Mga kaTsikot ayos na.
    Ang nang yari pala naglock yung left wheel ko kaya nagshake yung steering wheel ang ginawa pinalitan nang Rotors, Brake hose, Brake Fluid at Brake Pad okay na sya worn out na din kasi kaya pinalitan na.
    Then sa matigas na Steering wheel may niluwagan at hinigpitan lang.
    Umabot nang 18K lahat lahat.
    Wheel Aligntment nang Yokohama is hunter.
    Case closed
    thanks for the update👏👏👏
    Mar 2019
    hi, can you recommend po any auto shop near kalayaan makati? tie rod replacement. tried google pero along buendia/vito cruz na yung pinakamalapit. kinakabahan kasi ako baka biglang magbreak na siya if ibabyahe ko pa ng medyo malayo. thanks!
    Sep 2018
    hi ma ka tsikot,
    may experience din ako dito steering wheel shake, when i reach ~ 90 kph.. pinacheck ko recently, and ganito nila chineck yung auto ko.
    - rev up the engine, other guy check the engine mounts. - clear
    - jacked up, held the wheel on 3-9 and 6-12 oclock position, may play both front wheels.
    as per mechanic, eto yung need replacement. hingi lang ako ng advise if all of these needs to be replaced.. this would cost around 16k kase.. thanks.
    2 PCS RACK END - 3800
    2 PCS TIE ROD END - 2800
    2 PCS CV JOINT - 4300
    2 PCS TIRE BALANCING - 600
    CAMBER - 1950
    LABOR - 600
    Quote Originally Posted by reymund View Post
    hi ma ka tsikot,
    CAMBER - 1950
    LABOR - 600
    Tire balance mo muna
    Jan 2008
    hi ma ka tsikot,
    CAMBER - 1950
    LABOR - 600
    Wow mura ng labor... pero mukhang tinaga ka naman sa presyo ng parts..
    Usually yung play na yan sa wheels eh may kasamang TOK sound.. at upon close inspection makikita mo yung loose movement ng joints
    Sep 2018
    ay mali...3k pla labor. sa balancing yang 600 hehe..
Steering Wheel Shakes
