Results 1 to 4 of 4
April 6th, 2008 12:43 AM #1
tulong naman, kakabili lang namin ng ek hatch. so converted siya. ok naman daw ung rack and pinion, orig daw sabi ng mga mekaniko na pinatingin ko. problem ko is ung steering nya, mabigat siya tapos biglang gagaang. parang may oblong o baliko na kung ano man. may nakita din kaming leak ng power steering sa ilalim. ano kaya cause non? sabi kasi nung isang shop na napagtanungan namin baka nga daw may baliko tapos kaya nasira ung oil seal at tumagas na. kaso ang repair kit non is 3k daw tapos labor is 3k din. so mabigat bigat kaya isip pa ako baka may iba kayong naiisip na reason. sabi kasi makikita lang daw talaga ung sira kung bubuksan. so sira o buo cash-out na ko ng 6k..
tulong naman. thanks
April 6th, 2008 09:17 AM #2
Sasabunutan kita :D maloloka ako sa iyo hehehehe... malamang rack and pinion yan baka may slight bend yan. no use ang repair kit ma solve lang for awhile yun leak tapos tatagas ulit yan.
April 6th, 2008 09:44 AM #3
waaahhh... rack and pinion? diba mahal un? hehehe. pwede ba pa check yung kung may bend? yung tipong sisilipin lang and no need na magbaklas pa? hehehe.
thanks
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 18th, 2008 06:01 AM #4if the rack itself is not leaking then malamang hindi yun. i'd bet the ps high pressure hose is fabricated lang and not oem honda right? if so that is the cause of the the problem.
The backup charger finally arrived. Here are my findings and conclusion at the end:
