Results 1 to 4 of 4
- Apr 2011
- 24
May 6th, 2012 09:37 AM #1ano po kaya problem ng tsikot ko mga bossing, kapag steer ko siya sa left humihigpit at bumabalik pag binitawan pero pag steer ko sa right mas loose at magaan di agad bumabalik ung steering wheel. Pag binitawan yung steering at low speeds kumakabig siya sa right. Saan kaya may problema, sa steering kaya, sa suspension or sa tyres niya? salamat
- Apr 2011
- 24
May 6th, 2012 04:16 PM #4
check the basic and obvious first. check your tires, check your brakes. your tires tell a story what is wrong with your suspension, steering and brakes. if your car had been in an accident or has suffered impact from potholes or speedbumps at higher speeds, the right front tire (tire number two) might have been setback. your tires are the best "interviewee" if you know what you are looking for since they experienced road with the car it was installed on every inch of the wayLast edited by jick.cejoco; May 6th, 2012 at 04:38 PM.
Monk-owned R53
