Results 1 to 4 of 4
    Apr 2011
    ano po kaya problem ng tsikot ko mga bossing, kapag steer ko siya sa left humihigpit at bumabalik pag binitawan pero pag steer ko sa right mas loose at magaan di agad bumabalik ung steering wheel. Pag binitawan yung steering at low speeds kumakabig siya sa right. Saan kaya may problema, sa steering kaya, sa suspension or sa tyres niya? salamat
    Tire rid, rack end..make and model Ang car?
    Apr 2011
    04 toyota rav4 boss. stock ang wheels and tires.
    Feb 2009
    check the basic and obvious first. check your tires, check your brakes. your tires tell a story what is wrong with your suspension, steering and brakes. if your car had been in an accident or has suffered impact from potholes or speedbumps at higher speeds, the right front tire (tire number two) might have been setback. your tires are the best "interviewee" if you know what you are looking for since they experienced road with the car it was installed on every inch of the way
steering problem
