mga sir patulong nmn kc pagfull steer ako sa right my natulog na prang nasabit tapos my natunog.. i experience this since ngpapalit ako ng water pump.. ano kya sa tingin nyo mga sir?
Is your car a rear wheel drive or front wheel drive?
If its happens only when you turn right is sounds like the wheel bearing on the left(not right bearing). Check your wheel bearing on the left side. If it is a front wheel drive could be the CV joint, see if the axle boot kung torn up na.
i doubt it has anything to do with the waterpump. have the suspension checked.
oo sir toktok na malutong ang tunog pag full steer sa right dun din ung tunog sa front rightside..
if you heard that "tok tok tok tok" sound when steering to right.
then there's a high probability of a damaged right cv joint.
cv joint or velocity kapalit ko lang sa mb100 k nyan kahapon lang tapos pa repack ka na at bili ka ng boots para maagapan kung hindi pa sira yung kabila
now ang problem ko naman e tie rod?
mas maganda kung set ang papalitan mo left & right, para pareho ang presure & wear out, para hindi mag ka problema sa steering like kabig...
imo have it checked muna. kung lagi naman andun sound it should be relatively easy to pinpoint.
tnx sir speedy,nag browse ako sa HCP forum sabi baka daw kulang na rear differential fluid?
it's only the atf in the rear diff if you drive a crv. what car is this ba?
also, if it's the rear diff, it normally makes the same sound when turning left or right.
mga sir ganito rin problem ko ngayon sa car ko pag kakabig ako ng full steer or half steer to the left malakas yung tunog na ..."tok tok tak tak tak" maski ibalik galing sa steer habang umaandar pag right naman hindi ganun kalakas yng tunog, usually po ba outer velocity joint po ba ang sira? my car by the way is a 1984 ford laser, and usually how much is it(estimated price for front wheel cars)? should it be replaced? or can it be fixed by adding grease on it? naranasan ko lang ito 2 months after replacing my clutch, pressure plate and bearing .....
same din sa akin, isuzu bighorn pag kanan kahit half may tunog at pag arangkada minsan meron at preno ganun din minsan may tunog minsan wala ano kaya problema??
if the car is converted, start with what was done during the conversion.
