Results 11 to 19 of 19
June 28th, 2008 06:27 AM #11
mas maganda kung set ang papalitan mo left & right, para pareho ang presure & wear out, para hindi mag ka problema sa steering like kabig...
- Oct 2003
- 41
July 20th, 2008 08:07 AM #13
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 20th, 2008 11:10 AM #14imo have it checked muna. kung lagi naman andun sound it should be relatively easy to pinpoint.
- Oct 2003
- 41
July 20th, 2008 08:53 PM #15tnx sir speedy,nag browse ako sa HCP forum sabi baka daw kulang na rear differential fluid?
- Nov 2003
- 3,849
July 27th, 2008 10:52 AM #16it's only the atf in the rear diff if you drive a crv. what car is this ba?
also, if it's the rear diff, it normally makes the same sound when turning left or right.
August 5th, 2008 02:10 AM #17
mga sir ganito rin problem ko ngayon sa car ko pag kakabig ako ng full steer or half steer to the left malakas yung tunog na ..."tok tok tak tak tak" maski ibalik galing sa steer habang umaandar pag right naman hindi ganun kalakas yng tunog, usually po ba outer velocity joint po ba ang sira? my car by the way is a 1984 ford laser, and usually how much is it(estimated price for front wheel cars)? should it be replaced? or can it be fixed by adding grease on it? naranasan ko lang ito 2 months after replacing my clutch, pressure plate and bearing .....
- Aug 2008
- 6
September 1st, 2008 10:58 AM #18same din sa akin, isuzu bighorn pag kanan kahit half may tunog at pag arangkada minsan meron at preno ganun din minsan may tunog minsan wala ano kaya problema??
- Nov 2003
- 3,849
September 7th, 2008 07:46 PM #19if the car is converted, start with what was done during the conversion.
