Results 1 to 10 of 10
    Jul 2013
    Mga bossing may alam ba kayo gumagawa ng issue ko. Honda City 08 sya kung nag mamaniobra ko di bumabalik sa center yun steering wheel ko manual ko pang ibabalik. Dinala ko sa Servitek di daw nila kaya eh. any shop malapit sa las pinas?
    Feb 2009
    Quote Originally Posted by arjay17 View Post
    did you lower or alter your suspension? did you change the offset of the wheels? have you been in a frontal collision?
    Jan 2003
    electric power steering ba yang unit mo? non-centering na ata yung mga naka EPS kaya di talaga babalik sa center.
    Jul 2013
    di ko alam eh. yun isang honda city 08 ng barkada ko ganun din eh. kung normal lang pala ok lang.
    Pag nag-U Turn ka hindi bumabalik sa sentro?
    Jul 2013
    yes pag U turn di bumabalik sa sentro stuck lang sya not unless ikabig mo manualy. napa-camber and align ko na sya 2 months ago using R15 rims,
    Apr 2010
    Something to do with self centering mechanism. Check the whole linkage sir. Baka may leaks or bushings/boots/seals to replace.
    Peace out!
    Sep 2013
    2008 city is driven by EPS wala syang power steering fluid i have the same situiation i ask honda tech. normal lang daw yun ,,,,,, i hope so!!,, i ask naman some of my friend very complicated daw kapag yung EPS natin yung nag kaproblema,,,
    Jun 2010
    ganyan din yung glx-v limited namin di bumabalik , normal lang daw sa glx-v limited
    Jan 2013
    I had the same kind of problem a while back. I had my steering checked and my underchassis checked. Walang problema. Pero hindi pa din siya bumabalik sa center specially if fully turned yung wheel.
    So I had to live with the problem until I decided to correct the camber of my car an voila! Naayos yung steering wheel ko. Apparently, my SUV had a positive camber on both wheels and that caused the steering wheel to not return to the center. Search niyo na lang yung camber if you're not familiar, and minutong makita niyo illustration ng positive camber ma-gets niyo agad kung bakit hindi siya bumabalik ng kusa sa center
Steering not returning to center
