Results 1 to 5 of 5
- Nov 2008
- 7
October 4th, 2013 03:11 PM #1Nagpalit po ako ng 2 gulong sa front. Nanotice ko na after palitan ung 2 gulong sa front, naging sobrang talbog na po nung andar ko unlike before na hindi naman. Dati kasi 4 goodyear tires sya tapos ngayon, 2 goodyear sa likod, 2 nankang sa harap if it makes any difference. Pinacheck ko ung psi ng gulong 30 naman lahat. Ano po kaya problema nito...
October 4th, 2013 04:48 PM #2
Since bagong palit tires mo pa check mo mga items below tapos ganyan
1) Camber Correction and Wheel Alignment
2) Check the condition of the Shock Absorbers and other suspension parts
Good practice na rin kasi yung item 1 once nagpalit ka ng set of tires
October 5th, 2013 12:02 PM #3
if your ride is too harsh, it may be due to higher than recommended tire pressure or higher than recommended load range tire for your car. check to see that our tires are passenger car tires, this would have the "P" on the sidewall, e.g.; P185/65R13. if it is too bouncy, it may be due to your worn out shock absorbers or low tire pressures
October 5th, 2013 03:01 PM #4
- Jul 2012
- 62
October 7th, 2013 10:49 AM #5Pa check mo ung tires mo baka naman may bukol delicado un hehe.
Uhmm try to check ung sinabi ni sir jodski if hindi parin pa check mo na shock absorbers mo.
as an aside, in the olden days, anyone who does not move 'ala luksa during Holy Week, especially...
Traffic!
