Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Jul 2004
    My 2000 Civic is getting sign of wear.
    Ride is now shaky and uncomfortable, loosing some steering control and overall manueverability has deteriorated slightly. I miss the old days of having one of the best maneuveable ride.
    I don't have any problem of getting an OEM shocks (not sure of the price though) but if you can suggest a better shock at almost the same price then I might consider that.
    Should I go for fluid or gas for this type of ride.
    My objective is to retain the brand new riding comfort of my civic.
    Can you please help me decide which shocks to buy.
    Thanks in advance.
    Nov 2003
    go bilsteins. almost the price of oem shocks and will last you much much longer.
    Jul 2004
    speedyfix, Yes heard all praises for bilstein, last longer than the car itself. But from what i heard it much much expensive than oem ah.
    Jun 2004
    Are you sure the problem is with the shocks? Based on what you described I dont think its your shocks that need replacing.
    Does the car seem to bounce more now when going over humps or rough roads? If yes then replace your shock absorbers. If not check the wheel balance, tire condition, suspension bushings, engine mounts and so on...
    Dec 2003
    replace all the wear n tear suspension bits if you want to restore the handling and ride quality.
    Nasa magkano kaya ng price ng Bilstein shocks para Civic? yung OEM yata nyan ay Showa.
    mga 16-18k ata para sa comfort shocks IIRC.
    Jul 2004
    Definitely its shock. When I pushed the car body on four corners it bounce more than once. Very obvious that there is no more dampening action of the shocks. Wheel are aligned perfectly and other underchasis parts are all in good condition done by cruven. Gas ba o fluid type ang dapat kong ipalit?
    gas is a bit stiffer but better on the performance aspect. liquid is more comfy pero mas bouncy/maalon ang ride.
    Nov 2003
    last i checked bilsteins go for about 7-8k per shock. about the same as oem ones i think. slightly more expensive lang but not by much.
    Jun 2005
    Field Master, Ako rin naka 2000 na Civic (ES). Just had my front shocks replaced with KYB...5,200 isa. Ni-replace ko na rin tie rod, ball joint and stabilizer link. Nawala yung kalampag, langit-ngit and vibrations. Sarap na ng ride ulit! I can't compare it though to how it was when the car was brand new cause I hardly remember it anymore. Hope this helps!
    Question though, diba you had your underchassis parts re-conditioned by Cruven? I hear they also repair/modify shocks and refill them with Nitro...ayaw mo ba pa-repair sa kanila? Curious din kasi ako about it eh.
    Quote Originally Posted by franci_rod
    Gas ba Sir yang kayaba mo? medyo mahal kase?
    Feb 2005
    Pareho ba shocks ng Civic 2000 sa Civic VTec?
    what year model ng civic vtec???
    Medyo nakakalito kasi ang post ni franci_rod. AFAIK, yung ES model ng Civic ay unang lumabas ng year 2001. 2000 model Civik are still EK series.
    *zeagel : The Civic 2000 model is an EK model ( model 96-00 ). While the ES starts from 2001 - 'til now.
    I think eto ang grouping nyan :
    96-00 Civic (EK)
    01-05 Civic (ES)
    Jun 2004
    Parang medyo mahal yata yung shocks na yun ah, regular shocks lang ba yun or adjustable? Sa luma kong accord 1.8k lang bili ko per shock last year...
    Jun 2005
    Quote Originally Posted by wrcastro_ph
    I think so yes..mga magkano ba Kayaba for my ES na Civic?
    I asked for the price para sa EK naman 1,800 daw. Mas mahal daw talaga para sa ES kasi mas malaki yung shocks....they showed me, totoo naman na mas malaki talaga yung para sa ES. Not sure lang kung ganun dapat ang difference in price. Talagang desperate lang ako na maayos kaya pinatos ko na.
    Jun 2005
    96-00 Civic (EK)
    01-05 Civic (ES)
    wrcastro, my bad...I wasn't sure if we bought our civic 2000 or 2001 but I'm sure na ES yung amin. Apologies all around for the confusion. Hehe!
    Why don't you try refilling at Cruven or Zee first? It's only 2,800 all in all, same price as 1 piece of KYB.
    Jun 2005
    Quote Originally Posted by squala
    pare na-try mo na ba sa Cruven? Actually, I seriously considered having it repaired at Cruven pero wala ako nabasa na feeback if their work will endure. I've read comments from some that it felt like new after being repaired but I think that's just expected from something thats just been fixed. What concerns me more is the durability? I understand that cost is a major factor but having to go through the hassle of having it repaired again (and pay again) is also something.
    Share naman ng info. regarding Cruven kung meron ka. Kasi laspag na rin shocks nung 96 na civic ng sister ko eh. Kung ok dun, might as well have it repaired...luma na naman oto eh..chaka sa sister ko naman yun...basta umaandar at may aircon ok na! hehe!
Honda Civic Aftermarket Shock
