Results 1 to 10 of 25
February 24th, 2006 10:24 AM #1
My 2000 Civic is getting sign of wear.
Ride is now shaky and uncomfortable, loosing some steering control and overall manueverability has deteriorated slightly. I miss the old days of having one of the best maneuveable ride.
I don't have any problem of getting an OEM shocks (not sure of the price though) but if you can suggest a better shock at almost the same price then I might consider that.
Should I go for fluid or gas for this type of ride.
My objective is to retain the brand new riding comfort of my civic.
Can you please help me decide which shocks to buy.
Thanks in advance.
Tsikot Member Rank 5
- Nov 2003
- 3,849
February 24th, 2006 10:36 AM #2go bilsteins. almost the price of oem shocks and will last you much much longer.
February 24th, 2006 11:30 AM #3
speedyfix, Yes heard all praises for bilstein, last longer than the car itself. But from what i heard it much much expensive than oem ah.
- Jun 2004
- 1,311
February 24th, 2006 11:54 AM #4Are you sure the problem is with the shocks? Based on what you described I dont think its your shocks that need replacing.
Does the car seem to bounce more now when going over humps or rough roads? If yes then replace your shock absorbers. If not check the wheel balance, tire condition, suspension bushings, engine mounts and so on...
February 24th, 2006 11:58 AM #5
replace all the wear n tear suspension bits if you want to restore the handling and ride quality.
February 24th, 2006 12:48 PM #6
Nasa magkano kaya ng price ng Bilstein shocks para Civic? yung OEM yata nyan ay Showa.
February 24th, 2006 03:49 PM #8
Definitely its shock. When I pushed the car body on four corners it bounce more than once. Very obvious that there is no more dampening action of the shocks. Wheel are aligned perfectly and other underchasis parts are all in good condition done by cruven. Gas ba o fluid type ang dapat kong ipalit?
February 24th, 2006 04:00 PM #9
gas is a bit stiffer but better on the performance aspect. liquid is more comfy pero mas bouncy/maalon ang ride.
- Nov 2003
- 3,849
February 26th, 2006 12:36 PM #10last i checked bilsteins go for about 7-8k per shock. about the same as oem ones i think. slightly more expensive lang but not by much.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
