Results 11 to 20 of 32
February 29th, 2008 06:00 PM #11
Dimished? Getting there I guess. The pedal is going deep already but still managing.
As per checking, I'm at a phase that DOT 5 is not really "recommended". Well, I'll have to make it bleed again and change to DOT 4 if the guru niky says I need to . I'll try to check for these stainless lines you are talking about because I really don't know what it is. Thanks for the tip and I'll be doing this when money is on my side.
February 29th, 2008 06:15 PM #12
Stainless lines are maybe about 8k, maybe less, since you've got a Honda, after all. Good for pedal feel, but it'll do diddly squat for a deep pedal if your discs are already warped.
Good luck with your mods. ;)
March 1st, 2008 04:32 PM #14
saken maingay naman pag paatras lang na brake... what could be the culprit?
Tsikot Member Rank 3
- Oct 2006
- 1,069
March 1st, 2008 05:37 PM #15Buy US made stainless braided lines. Locally fabricated lines are NOT of the same quality. The lines usually separate from the fittings.
Tsikot Member Rank 5
- Nov 2003
- 3,849
March 2nd, 2008 10:38 AM #16runstop has decent rotors. they should be around 8k for a pair depending on application and size.
tanabe pads are good enough na pang everyday.
earls or goodridge lines and ATE brake fluid.
March 3rd, 2008 01:33 PM #19
March 3rd, 2008 01:49 PM #20
[QUOTE=JCBalunsat;1020533]Dimished? Getting there I guess. The pedal is going deep already but still managing.
Sir, have you had your brake repair kit checked? This usually causes the pedal to go deep when braking, sometimes to the point that you have to pump the pedal before the brakes start to bite .
I'm also using bendix (metal king) on my ride and yes, they cause the whistling sound. This tends to get louder and irritating if the rotors are full of brake dust.
I do agree with sir mazdamazda that slotted disks are not cheap. But good brake pads are a good investment. If you take good care of your discs, they will last longer than your stock pads. I've had mine for 4 years now.
HTH and saves you an arm and a leg
Good day to all !!!
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
