Results 11 to 14 of 14
May 7th, 2008 03:49 PM #11
this is how i do it on an A/T whenever i park on an incline.
foot brake while shifting to neutral > pull the hand brake > release foot brake, the car will move a bit, then foot brake again while shifting to park > turn off engine.. in this way, the stress is on the brakes and not on the tranny.
imho, it's much cheaper to replace the brake pads than a tranny..
May 7th, 2008 08:57 PM #12
OT: bakit sa mga large SUV ayaw mag lock ng hand brake? then pag incline then paatras halos walang power ang handbrake? based on my expirience po ..
May 7th, 2008 09:41 PM #13
Happened to me last month when my handbrake started to slip more often so had the following done at a reliable local shop:
1. Had the rear drum brakes cleaned with Brake Cleaner.
2. Had the tension adjusted.
Solved the problem.
By the way, in order to ensure that your rear drum brakes has the correct setting, spin the drum - it has to have a certain resistance to the spin. It must not spin loosely.
HTH.
May 7th, 2008 11:40 PM #14
If you've got the lever-type handbrake as found on most cars, the lever should run out of travel after 4-7 clicks.
If you've got the floor-type handbrake used on pickups and trucks, you'll have to listen to 16-24 clicks (based on our old LiteAce's owner's manual).
Any more and you probably need to have the handbrake cable adjusted. No bleeding necessary as the handbrake's operation involves zero brake fluid, anyway.
Xiaomi E-Car
