Results 1 to 13 of 13
    Oct 2007
    Yung '93 pajero biglang lumalim apak sa brake last saturday.Pag-check ko ng Sunday morning wala na pala brake fluid kaya nilagyan ko.Naging ok na yung apak ko sa brake.Di na malalim.Umikot ako konti tapos lumalim nanaman.Pagtingin ko ubos nanaman brake fluid nya tapos sa ilalim ng sasakyan sa bandang likod ang daming tagas.What was possibly ruptured to cause this and how much would it cost to fix it?Pano ko dadalhin sa shop ang sasakyan na ganito kondisyon?Tulong naman po.salamat.
    Nov 2007
    boss baka master break yung nasira yung naka sama sa break drum dun malamang ang tagas nyan di ko alam kung magkanu
    pwedeng pa serbisan mo na lang sa garahe mo o kaya bili ka ng 2 break fluid tiyagain mo na lang dalhin sa pinaka malapit na shop or gas station??
    May 2007
    1. Kung yong Master Cylider ng brake ang sira may mabibiling kit para i rebuilt yan which easy to do.
    2. Kung yong piston caliper naman ang may sira, meron din kit yan. Again, napakadaling gawin.
    3. Kung yong rubber brake lines naman ang sira palitan mo nalang ng mas matibay na brake lines(ex. performance stainless steel brake lines).
    All of the above na sinabi kong madaling gawin ay ONLY IF YOU ARE MECHANICALLY sounds.
    Oct 2007
    v6dreamer,
    any ballpark figure kung magkano yung mga kits na nabanggit mo?para lang di ako nagugulat pag bumibili na ako kung sakaling isa nga sa mga nasabi mo ang kailangan ko. salamat ulit.
    May 2007
    Quote Originally Posted by RedCoder1 View Post
    v6dreamer,
    Dito mura lang which is your Pajero is similar to Montero (USDM). Call your local Auto supply or Mitsubishi car parts(dealer) for pricing.
    Jul 2003
    brake wheel cyclinder can cost anywhere from 600php. better to replace the assembly if it had rusted out. you may also want to inspect all brake cylinders for impending problems.
    Nov 2011
    Quote Originally Posted by v6dreamer View Post
    Puedi po ba akong Humingi ng tulong dito?
    Saan po ba ako makakabili ng Caliper repair kit, front brake ng ElGrand ko (Double piston po)
    Email lang po sana ang address and Telephone number.
    Maraming salamat po.
    Dec 2007
    hey bro, it seems that you have a leaking Wheel Cylinder (or Rear Wheel Cylinder.. specially if you have Rear Drum Brakes, which I think you have.) anywayz, I would suggest getting the Wheel Cylinder's replaced on both sides (left & right) and as the same time replace the Brake Shoe.. but if the shoe's are still ok, then just leave it alone.
    also, pwede din na i-rebuild ang wheel cylinder, but you have to buy a rebuilding kit for it.
    aite, peace.
    Oct 2007
    Quote Originally Posted by KBR View Post
    aite, peace.
    Ilan po ba ang wheel cylinders?Isa ba sa bawat gulong?saan po location nito?yung tagas kasi, kung nasa likod ka ng sasakyan, dumadaan sa may gitnang bahagi nung bakal(di ko kasi alam ano tawag dito. Pasensya na po ) na parang dumudugtong sa dalawang gulong sa likod.Yung sa parang bilugan na bahagi nya.Dun dumadaan yung fluid.Kung brake lines sa may caliper piston ang may tagas malapit sa gulong po ba mismo dapat ang tagas nya?
    Dec 2007
    hey bro, isa lang ang Wheel Cylinder per side ng brakes. also, yung wheel cylinder ay located mismo sa loob ng brakes (behind the Brake Drum) so kailangan tanggalin yung Drum, then makikita mo na yung wheel cylinder. yung wheel cylinder ay yung nag pu-push sa brake shoes para mag contact ang shoes sa drums.
    anywayz, kung may tools ka (or jack and stands) tanggalin mo yung gulong, then yung brake drum (make sure hindi naka taas ang E-brake.. kundi mahihirapan ka sa pag tanggal ng drum). and pag mahirap kalasin ang drum, konting pukpok lang ng martilyo (or a soft dead blow hammer) makakalas na agad yun. then makikita mo na ang wheel cylinder at ang brake shoes.
    aite, peace.
    Dec 2007
    ok, heres some links that I find pretty helpful... for all of us!
    http://www.huntersupport.com/pub/und...690T/index.htm
    http://www.aa1car.com/library/2003/bf60330.htm
    aite, peace.
    Oct 2007
    edited this
    Oct 2007
    Thanks for the help guys! Mukhang yung Master Cylinder nga ang may sira.Got a chance to look under the vehicle yesterday.Lumalabas yung fluid sa point na nag-iintersect yung tatlong tube.Two going to the two brake lines to the wheels on the rear side of the vehicle and the remaining tube is coming from the front side of the vehicle if I'm not mistaken.Naguguluhan lang ako kasi yung intersection nung tubes ay octagon ang shape.Eight sided kung tama ang bilang ko.hehe.Hindi sya cylindrical as the name "Master Cylinder" implies.O baka casing lang ito at nasa loob nun ang Master Cylinder???tia!
Tagas sa brake
