Results 1 to 10 of 10
    hello mga sir, share ko lang problem sa car ko,,makalampag kc ung car ko at parang nagmumula sa rear bumper ko. Naisip ko baka lumuluwag na mga screws.. gusto ko sana iswap na lang rims ko e kaso ayaw ni misis kc maporma daw at un nalang nagdadala...so nagdecide ako baka makuha sa pagpalit ng shox..ano po ba mgandang brand and ung mura?? Car po namin is 92 Nissan Eccs. thanks and God Bless.
    Dec 2009
    Quote Originally Posted by yuri_0809 View Post
    sir same tayo ng problem, sakin din sa likod, mazda 3 car ko.. meron nag ofer sakin KYB KAYABA shock absorber 13.6k rear and front shock absorber kasama na kabit.. madami good feedback sa KYB... search mo na lang dito sa tsikot yung KYB tread..
    Feb 2011
    pa check mo yung mga bushings baka worn out na, next is shock absorber baka wala ng play at ubos na yung gas or fluid, next is yung tire baka naka low profile kayo, makalampag talaga yan..imo lang naman..
    Jul 2003
    iba ang kalampag sa tagtag. so which are you experiencing?
    May 2009
    both siguro bro....kalamtag. hehe
    May 2009
    the less rubber, mas less din ang shock absorbing ability ng tire.....like in my case, i was running M//Ts before then switched to A/Ts. lesser driving comfort.
    Jul 2003
    Check if anything loose is being stored in the trunk, secure them all or provide some cushion
    Check rubber bushings
    Replace shocks insulator block.
    Replace shocks shaft bumper.
    If budget permits, replace with new rear shocks.
    May 2009
    vibrations come in various types when you start modifying or stray from oem specs...
    some of these modifications are"
    1. Lifting the vehicle effecting increased driveshaft angles
    2. Larger tires can also increase steering and geartrain components. a bigger tire will require greater effort to turn causing accelerated wear and tear of steering and suspension components.
    an unbalanced tire or low air pressure may have great effect on steering and stability.
    Follow a systematic diagnosis.
    1. air up the tires
    2. check suspension mounts, steering gear mounts, shock mounts, tie rod ends, ball joints.
    3. check the movement of steering parts by having someone steer the wheel back and forth.
    4. (others may want to continue the list)
    uhm,,pakiramdam ko parang wala na akong gulong e,,parang rim na lang sumasayad sa kalsada..plus nga ung kalampag sa bandang rear bumper. Gigil na nga ako magpalit ng gulong e, kung di lang dahil kay misis,,jejejeje...
makalampag kapag napapadaan sa lubak,,dahil ba sa 17 inches rim??
