Page 1 of 3 123 LastLast
Results 1 to 20 of 45
    Jun 2007
    recommend naman kayo ng shop na specialist ng power steering (magaling at mura pa) nakita ko may leak yung tubo ko e gusto ko na sanang paayos bago pa pumutok I-think pressured siya e
    thanks tsikoteers
    Nov 2003
    get the oem ps hose if it is the high pressure hose. if you have it repaired or replaced with a replacement one, 90% yung chance na iingay yan when you turn the wheel.
    Taga san ka ba? Kung around Pasig, Marikina, part Cainta, Antipolo, & QC. try mo 'to:
    Multi-Flex Enterprises
    #223 Amang Rodriguez Ave., Santolan, Pasig (near Mickey's Auto Sound & South Supermarket)
    Tel: 6821491
    Dealer ng mga automotive, industrial hydraulic hoses sila. May mga branch ng casa ng Toyota, Mitsu, Nissan, Honda pati Ford sa kanila kumukuha at nagpapagawa.
    Jun 2007
    thanks sa suggestions niyo mga sirs todo ingay na ng power steering ko
    Aug 2004
    Pakiramdam ko kasi parang sobrang lambot ng steering wheel ko po eh. Parang may play yata lalo na pag tumatakbo. Pwede kaya na rack end pinion clamp bushing ang problem ko?
    question po: after i had my sentra detailed, medyo may maganit na ung steering wheel pagnit-turn (while full stop) at parang mabigat sya iikot. the former (the maganit feeling) sabe sa shop mawawala din daw un. is it because of power steering oil? low na kaya sya?
    wala po kasi akong alam eh. please help me (yet again)
    super thanks po!!!
    Same here, slight diffrence sa steer wheel, seems like stiff pag turn ko, pero i tried my brother's civic, mas madali. ? any ideas on what to check po? TIA
    Quote Originally Posted by macychic View Post
    super thanks po!!!
    ayos na po... hehe, uu nga. oil lang thanks po.
    Question din po: pwede ba gumamit ng power steering fluid reservoir ng ibang sasakyan para sa ibang sasakyan? nacrack kasi yung sa sasakyan namin at nagleleak yung fluid wala naman ako mahanap na para sa sasakyan namin.. 96 mb100 po yung sasakyan namin..
    FYI: powersteering differs from car to car ...
    pag may leak ang powersteering mo ... may mga repair kit para diyan ... depende what kind of car it is ... usually in banawe area completo sa repair kit and parts ...
    for the reservior kahit anong klase okay lang basta ba fit and walang leak
    for those maingay yung powersteering while turning powersteering hose ang problem mo ... and kailangan mo palitan ang hose mo ng orig or japan oem parts ... not local parts
    and usually recommended na powersteering fluid ang lagay sa steering fluid not ATF especially honda cars which is pretty maselan ...
    hope this helps
    BANAWE AUTO SUPPLY
    regy
    Quote Originally Posted by hyperthread View Post
    usually powersteering clamp and problem mo ... the parts is cheap but the labor is expensive ...
    pwede rin yung isang shocks mo sira na so the car is unbalance kasi meron isang instance na sira yung shocks niya ... the steering becomes very hard pero paminsan minsan lang
    Cencya na, medyo malilihis thread na ito, pero ako din, once nagpa detail, me lumabas na problem. Kaya after that, naiisip ko ako na lang talaga maglilinis ng sasakyan ko. Sa tingin ko nakakasama high pressured water. Kung saan2x nakakapasok. Hindi naman talaga kailangan ito. Nakakapabilis lang ng trabaho sa part nun detailer.
    Nov 2003
    it's best to get the reservoir for your car. tyaga lang ng hanap.
    Apr 2006
    Quote Originally Posted by banawe View Post
    regy
    sir, saan po nakakabili ng steering fluid na hindi atf? at anung brand?
    wala kasing ganito sa gas stations eh. atf lagi ang offer nila.
    also, if you are familiar with nissan california's PS cap/gauge, dalawa po ang indicator niya - hot and cold. anu kaya ang susundin ko dun when filling up the reservoir?
    thanks
    naku, update lang po mga peeps, last night (less than 24 hours nun naglagay ako ng power steering oil) umingay na naman un steering wheel. i had it checked sa shell. then they told me na lumuwag daw un belt ng oto ko, kaya raw po bumibigay un hose, at kaya tumatagas agad ang nilalagay kong steering oil. or either nabasa un hose ng chemical na ginamit sa nun nagpaengine detailing ako (sa denjo, sa tabi ng Kilometer 2) hay, gastos na naman. palagi na lang akong malas sa shops :flush:
    makikitanong na rin po...
    inilusong ko kasi ung oto ko sa baha kanina, siguro almost half ng gulong ung baha. napansin ko na mahina preno ko and maingay ung power steering pag nkasagad kabig ng steering wheel sa magkabila. check ko ung level ng fluid ok naman. posible kaya na ung belt ay nabasa at lumihis??? toyota corona po ride ko. TIA
  17. #17
    pasabit:
    if the powersteering fluid foams and parang may nginig ang syatem pag nililiko mo what does that mean?
    kahapon ko lang to nangyari, habang malamig/bagong start, pero pag mainit or tumakbo na ng malayo-layo wala na...
    nga pala, last sunday, i accidentally put a used ATF kasi i thought its the new one.. (moral lesson: separate your new ATF from the used ones! especially when you use the container that is the same from your new ATF)
    will flushing and refilling solve this?--nangyari lang kasi nalagyan ko yung used ATF, e!
    maraming powersteering fluid sa market ... castrol, STP, honda has its own powersteering ... basta usually powersteering fluid is malapot konti and whitish in color
    dun ka lang sa cold ... kasi ibig sabihin yan pag running yung car mo it reaches dun sa hot guage ...
    Quote Originally Posted by grantt View Post
    your problem is sinugod mo sa baha
    well your problem is pag nabasa ang brakes usually umingay ito and malakas magkalawang yung mga rotor disc mo and caliper in your car
    for the noise you here while turning ... i think your problem is velocity joint ... meron kasing axle boot which covers your axle near your wheel ... pagbutas yun ... pumaposk yung water ... especially pag nululusong sa baha ... which causes your velocity joint to rust and break ...
    advice ... repack your axle or change you velocity joint ... buy a good king or grease to repack it ... not generic one ...
    BANAWE AUTO SUPPLY
    7120115
    regy
    Quote Originally Posted by alwayz_yummy View Post
    pasabit:
    actually putting ATF is not recommended for powersteering .... pero kung matigas ang ulo mo ... you should buy ATF dextron III and mercon or higher ... not ordinary ATF type A
    for the fluid foaming ... i think may hangin lang yung powersteering mo ... usually mawawala rin yan ... pero if you wanna be sure ... flush it and replace the fluids ... or try bleeding it ... para mawala yung hangin ... ask your mechanic about it
    but my advice replace it you powersteering fluid or ATF dextron III or higher
    BANAWE AUTO SUPPLY
    7120115
    regy
Power Steering
