Results 1 to 10 of 45
September 21st, 2007 01:04 AM #1
recommend naman kayo ng shop na specialist ng power steering (magaling at mura pa) nakita ko may leak yung tubo ko e gusto ko na sanang paayos bago pa pumutok I-think pressured siya e
thanks tsikoteers
Tsikot Member Rank 5
- Nov 2003
- 3,849
September 23rd, 2007 03:38 PM #2get the oem ps hose if it is the high pressure hose. if you have it repaired or replaced with a replacement one, 90% yung chance na iingay yan when you turn the wheel.
September 23rd, 2007 09:59 PM #3
Taga san ka ba? Kung around Pasig, Marikina, part Cainta, Antipolo, & QC. try mo 'to:
Multi-Flex Enterprises
#223 Amang Rodriguez Ave., Santolan, Pasig (near Mickey's Auto Sound & South Supermarket)
Tel: 6821491
Dealer ng mga automotive, industrial hydraulic hoses sila. May mga branch ng casa ng Toyota, Mitsu, Nissan, Honda pati Ford sa kanila kumukuha at nagpapagawa.
September 25th, 2007 10:28 PM #4
thanks sa suggestions niyo mga sirs todo ingay na ng power steering ko
September 26th, 2007 11:15 PM #5
Pakiramdam ko kasi parang sobrang lambot ng steering wheel ko po eh. Parang may play yata lalo na pag tumatakbo. Pwede kaya na rack end pinion clamp bushing ang problem ko?
September 27th, 2007 12:40 AM #6
question po: after i had my sentra detailed, medyo may maganit na ung steering wheel pagnit-turn (while full stop) at parang mabigat sya iikot. the former (the maganit feeling) sabe sa shop mawawala din daw un. is it because of power steering oil? low na kaya sya?
wala po kasi akong alam eh. please help me (yet again)
super thanks po!!!
September 27th, 2007 02:54 AM #7
Same here, slight diffrence sa steer wheel, seems like stiff pag turn ko, pero i tried my brother's civic, mas madali. ? any ideas on what to check po? TIA
September 28th, 2007 11:23 PM #8
September 29th, 2007 04:10 PM #9
Question din po: pwede ba gumamit ng power steering fluid reservoir ng ibang sasakyan para sa ibang sasakyan? nacrack kasi yung sa sasakyan namin at nagleleak yung fluid wala naman ako mahanap na para sa sasakyan namin.. 96 mb100 po yung sasakyan namin..
- Sep 2007
- 215
September 29th, 2007 05:56 PM #10FYI: powersteering differs from car to car ...
pag may leak ang powersteering mo ... may mga repair kit para diyan ... depende what kind of car it is ... usually in banawe area completo sa repair kit and parts ...
for the reservior kahit anong klase okay lang basta ba fit and walang leak
for those maingay yung powersteering while turning powersteering hose ang problem mo ... and kailangan mo palitan ang hose mo ng orig or japan oem parts ... not local parts
and usually recommended na powersteering fluid ang lagay sa steering fluid not ATF especially honda cars which is pretty maselan ...
hope this helps
BANAWE AUTO SUPPLY
regy
