Results 1 to 13 of 13
    Jun 2006
    tanong ko lang po lowered kasi car ko, need to replace shocks. naka lowering springs po sya. iisa po ba ginagamit n shock ng stock at lowered? btw civic 99
    Sep 2013
    KYB gas shock absorber bilhin mo
    Jun 2006
    i mean sir same lang size nung shock kapag naka stock springs or lowering springs? at nasa magkano po ganun? thanks sir
    Sep 2013
    ^alam na ng pagbibilhan mo nyan dahil sila naman magkakabit nasa 2k plus isa paps depende sa bibilhan mo sa akin 2200 bili ko, civic ek din car ko
    Oct 2009
    Quote Originally Posted by step22 View Post
    yes sir same lang ang maiksi lang sayo ung spring kasi lowering siya.un ngalang talagang pwersado ang shock mo.
    1.7K 1pcs kuha ko sa las pinyas kingsport.
    If you have the extra budget, get the KYB AGX shock absorbers. They have an 8-point setting to allow for adjustments in stiffness. The base KYB Excel-G gas shocks are good as OEM replacements but a better shock absorber will suit lowered vehicles. However, dami na rin gumagamit ng Excel-G for lowered vehicles so I guess they will be fine for the budget conscious.
    Kung malaki yung budget, coilovers na gamitin mo.
    Jun 2006
    thanks sa reply nyo guys. san kaya dito sa batangas laguna area meron?
    Mar 2016
    Kapag matagtag na ang lowered na auto, shocks lang ba papalitan or pati spring, bushing, etc? TIA
    Quote Originally Posted by okidokmd View Post
    pag matagtag lalo na kung naka lowering springs na, normally shocks but there are times na kailangan na rin palitan yung mga joints.
    pero kung putol springs lang, talagang matagtag yan.
    Mar 2016
    Quote Originally Posted by 1D4LV View Post
    Lowering springs naman. Thanks sir.
    Jun 2016
    Hi guys, may tanong ako, I have 205 40R 17 for my rear, and Ive noticed na masyadong malapit ung tire(sidewall) sa shock's perch(~0.3 inch clearance between shock and tire's sidewall). Yung shock's perch height clearance naman from the tire's tread is around 1 inch naman.
    So the questions are
    - Is the clearance of ~0.3 inch between the shocks(perch) and the tire's sidewall safe? Pwede ba ako magsakay ng mga 3 tao sa likod ng kotse?
    - Is the clearance of 1 inch between the shocks(perch) and tire's tread safe?
    Quote Originally Posted by Karl Engbino View Post
    imho, i think it would be alright as long as hindi fully loaded yung likod mo.
    i think max you can put there is two people, otherwise kakayod yan sa gulong, mapupudpod and hindi magiging safe.
    Aug 2004
    This is the lower perch? That will move along with the tire, so a tight clearance there isn't an issue. When the tire deforms under load, compression on the bottom will not make the sidewall bulge out at the top.
shocks on lowered car
