Results 11 to 13 of 13
- Jun 2016
- 24
July 2nd, 2016 09:34 AM #11Hi guys, may tanong ako, I have 205 40R 17 for my rear, and Ive noticed na masyadong malapit ung tire(sidewall) sa shock's perch(~0.3 inch clearance between shock and tire's sidewall). Yung shock's perch height clearance naman from the tire's tread is around 1 inch naman.
So the questions are
- Is the clearance of ~0.3 inch between the shocks(perch) and the tire's sidewall safe? Pwede ba ako magsakay ng mga 3 tao sa likod ng kotse?
- Is the clearance of 1 inch between the shocks(perch) and tire's tread safe?
July 4th, 2016 09:34 AM #12
July 4th, 2016 02:48 PM #13
This is the lower perch? That will move along with the tire, so a tight clearance there isn't an issue. When the tire deforms under load, compression on the bottom will not make the sidewall bulge out at the top.
high idle RPM at engine start
