Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Jun 2013
    Pa tulong naman aku sa inyo mga bossing..
    ung toyota corolla 96 ko may toktok sound sa front right or left wheel.. (dko sure san banda pero ang sigurado sa harap)
    Maririnig mo ang toktok sound in low speed (20kph).. sa humps maririnig mo din...
    kahit sa flat roads maririnig mo.. pero kapag medjo mabilis na ang takbo wala ng toktok sounds..
    san kaya galing ang tunog? pa help lng aku kc baka ma loko aku ng mekaniko..
    Oct 2005
    Sounds when turning? Or when travelling straight roads?
    Either ball joints or CV joint or both.
    HTH.
    Oct 2008
    Dre, mas mabuti dalhin mo na sa car shop para matingnan ng mabuti.
    it can be as simple as something which is stuck within the threads of the tire kung bago ang gulong.
    or a wheel bearing.
    dapat makita and ma check up ng mabuti.
    Jun 2013
    yes tumutunog kapag lumiliko pero mahina lng.. mas malakas ang tunog kapag travelling straight roads in low speeds..
    if ball joint or cv joint magkanu kaya mag pagawa sir?.. kasama materials..
    Jun 2013
    Quote Originally Posted by 1D4LV View Post
    or a wheel bearing.
    kung wheel bearing sir.. how much po ang labor ang materials?..
    gensan kc aku sir marami mekaniko d2 nag tatake advantage..
    gusto ko po sana may alam aku before dalhin sakanila..
    Jul 2011
    Quote Originally Posted by kentrials View Post
    usually sir ang paunang lunas sa CV joint (if cv joint ang problema) is repack lang muna bago replace the whole joint, had the same model ng car Corolla 95 naman, and may lumalagutok sa kanya lagi, and positive ako na its coming from the CV joint, so pinarepack ko lang, and okei na, eversince hindi na tumunog, be sure lang na tanggalin yung old grease bago lagay yung bago, wag mo hayaang ihalo lang yung bagong grease sa luma.
    and if balljoint naman (if ball joint naman ang problema), replace na yan, alam ko sealed type ang balljoint ng corolla, so hindi pwede yung iniinjekan lang ng grease like other cars.
    Jun 2013
    Quote Originally Posted by 7138 View Post
    salamat sir.. dadalhin ko ngun ung kotse sa shop.. kapag CV joint ipapa repack ko lng muna salamat po.. big help
    Jul 2011
    If magpapa-repack ka na, use ONLY cv grease, hindi yung basta basta grasa lang. may dedicated grease for cv joints.
    and also check mo nadin mga boots, pag may punit or kahit isang butas lang, palit na, maulan pa naman ngayon, dibale kung tubig lang, (thou wala din dapat makapasok na tubig), eh may kasamang lupa/buhangin, didikit pa sa grasa yun and iikot na sya ng iikot dun, gagasgasin nya cv joints mo.
    Jun 2013
    sir ball joint ang problema.. sa right side.. pinagawa ko na.. 900 ung ball joint plus 300 labor.. nawala na ang tunog.. 1,200 lahat na gasto ..
    tnx sa tips ang info
Help TokTok sound in my Toyota Corolla 96
