Page 9 of 15 FirstFirst ... 5678910111213 ... LastLast
Results 161 to 180 of 296
    Jun 2011
    #161
    sir, magpapalit po ako ng mga shocks na toyota gli di ko po alam kung ano pwede ipalit dun sa dati medyo mahal mo kasi ang kyb. okey lang ba yung titan shocks kaso di ko po alam kung orig yun fluid type po cost about 1400. pwede po bang makahingi ng advice.
    #162
    im not familiar with titan shock. i replaced my previous car (civic 2000) with kyb and its stiffer than oems and its gas type pero up to now wala pa nasisira kahit isa. yung tokico are cheaper by 200 i think, if i can remember it right. fulid type and closer to oem than the gas kyb.
    Aug 2010
    #163
    how about monroe shocks?
    Quote Originally Posted by edgardgamboa View Post
    sirs, how much will it cost for a pair of monroe shocks absorbers for mitL-300...ty po.
    depends upon the store pero about 1,000-1,400 per piece ata yung sa L300 nang office dati.
    Aug 2010
    #165
    anong brand and model no.?
    Quote Originally Posted by trucker111 View Post
    hehe, sorry I forgot it na bro, 2006 pa yun nung pinalitan eh.
    Aug 2011
    #167
    Quote Originally Posted by banawe View Post
    hey guys if your looking for cheap kayaba shops ... pm me i will give you the cheapest price ... if you don't believe me try calling or pm me
    BANAWE AUTO SUPPLY
    regy
    Sir regy, how much ang cheap kayaba mo for toyota altis front and rear, aside from cheap kayaba shock absorber what is your cheapest shock absorber and how much . . .
    thanks,
    bartu
    #168
    Quote Originally Posted by bartu View Post
    thanks,
    bartu
    Cheap shocks Korea is about 1350* frt, while the rear is 1000* for inquiries call the store
    #169
    Quote Originally Posted by buboydc View Post
    sir favor pls....pa-quote ng kyb front shocks for corolla xe 97. thanks in advance. more power
    Kayaba shocks for this model is fluid 2100*, while the gas type is 2400* front and rear same price
    Dec 2009
    #170
    sir how much ang KYB shock absorber nyo for mazda 3 2.0? front and rear? and ok lang ba kung (excel G - front) and (Gas a just - rear)? may nag quote sakin ng ganun eh... ano sa palagay nyo? pa pm sir nung price ng KYB front and rear shock absorber for my ride.. salamat..
    Sep 2009
    #171
    Quote Originally Posted by aejhayl17 View Post
    more or less 10k plus labor na din. kay sir banawe, banawe auto supply ata. back read ka na lang sa thread na to, nandun contact no. niya. few pages behind lang
    Gas shocks are more intended pag ang auto mo is gamit pang buhatan on the rear part of your car. But if you use your car on a daily basis and minimal lng din yung load na dala-dala mo, you will really notice that ang tigas ng bagsak ng ride mo pag naka gas type ka
    . Thats why hangang ngayon eh still OEM released ang mga fluid type shocks sa mga newer cars dahil that one is still tested to give you a more smoother ride. JIL store in banawe corner e.rodriguez sells KYB shocks for AUV's at around 600pesos and KYB gas type at around 1,200 yta, double the price of the fluid type then just have it installed to one of your favorite gas stations.
    Nov 2011
    #172
    sirs, need suggestion on front shock replacement, compliance bushing and wheel alignment for civic 2002 Vti-S.
    nag canvass ako sa honda, magkaiba presyo binigay for left and right dahil sa ABS.
    any suggestions sa shop sa banawe area (diagnosis+parts+labor)?
    suggestions sa alternative sa OEM parts welcome din. thanks.
    Dec 2011
    #173
    mga sir ask ko lang if pano mo malalaman kung palitin na yung shocks, sorry bago lng sa tsikot world..
    medyo bumagsak kase sa left sideyung oto ko.. takot lang ako bka lumalala.. TIA
    #174
    Quote Originally Posted by theboneidentity View Post
    Wheelers Suspension Haus in Banawe used to do the suspension work on my old 2001 ES body Civic. They can also source the parts for you and you can cross-canvass with shops such as Multiline (?).
    Quote Originally Posted by pniverba View Post
    If you do a bounce test or while you're driving, the car bounces more uncontrollably when it hits dips. If you do a visual test, there's fluid leaking out. Best to have your mechanic check it also as it may also be the spring and not the shocks.
    Dec 2011
    #175
    thanks sa advice sir.. pmunta kase ako sa cruven yday kaya lng sarado pala sila...
    nka tanabe lowering springs kase ako... chineck ko nman wala nman leak..
    as far as sa ride wala nman akong nararamdaman na bounce maybe kase nka lowered?
    thanks!
    Jan 2012
    #176
    does anybody knows where i can buy original toyota spare parts such as brake pads, shock absorbers, window motor, door locks and many others whose prices are not same as that of toyota parts dealer... my immediate need is front shock absorbers for toyota vios 2006. would you know what brand of shox toyota uses for vios 2006? pls help me find stores... thank you..
    Jan 2012
    #177
    does anybody know where i can buy original toyota spare parts such as brake pads, shock absorbers, window motor, door locks and many others whose prices are not same as that of toyota parts dealer... my immediate need is front shock absorbers for toyota vios 2006. would you know what brand of shox toyota uses for vios 2006? pls help me find stores... thank you..
    #178
    Quote Originally Posted by marymartha View Post
    Go for KYB or Tokiko shocks. Try calling Toyorama or NGK Auto Parts in Banawe (numbers can be googled).
    Jan 2012
    #179
    thank you so much po sir, i will call them asap. kyb brand po ba ay same as kayaba brand na kine carry ng SERVICTEK? thank you po again.
    #180
    Yes, it's the same.
shock absorber replacement
