Results 1 to 20 of 296
    Quote Originally Posted by theboneidentity View Post
    sirs, need suggestion on front shock replacement, compliance bushing and wheel alignment for civic 2002 Vti-S.
    nag canvass ako sa honda, magkaiba presyo binigay for left and right dahil sa ABS.
    any suggestions sa shop sa banawe area (diagnosis+parts+labor)?
    suggestions sa alternative sa OEM parts welcome din. thanks.
    Wheelers Suspension Haus in Banawe used to do the suspension work on my old 2001 ES body Civic. They can also source the parts for you and you can cross-canvass with shops such as Multiline (?).
    Quote Originally Posted by pniverba View Post
    mga sir ask ko lang if pano mo malalaman kung palitin na yung shocks, sorry bago lng sa tsikot world..
    medyo bumagsak kase sa left sideyung oto ko.. takot lang ako bka lumalala.. TIA
    If you do a bounce test or while you're driving, the car bounces more uncontrollably when it hits dips. If you do a visual test, there's fluid leaking out. Best to have your mechanic check it also as it may also be the spring and not the shocks.
    Dec 2011
    thanks sa advice sir.. pmunta kase ako sa cruven yday kaya lng sarado pala sila...
    nka tanabe lowering springs kase ako... chineck ko nman wala nman leak..
    as far as sa ride wala nman akong nararamdaman na bounce maybe kase nka lowered?
    thanks!
shock absorber replacement
