Results 1 to 10 of 20
November 16th, 2007 01:34 PM #1
ano ba talagang mas maganda between a fluid type and a gas type? which is more suited for our road conditions? pros and cons in using either one?
November 16th, 2007 01:39 PM #2
November 16th, 2007 01:53 PM #3
Comfort: fluid front and rear
Hauling: gas ako esp rear in comb with fluid in front
Lowered: gas front and rear
Tsikot Member Rank 2
- May 2006
- 913
November 17th, 2007 08:13 AM #5The prime function of gas charging is to minimize aeration of the hydraulic fluid. The pressure of the nitrogen gas compresses air bubbles in the hydraulic fluid. This prevents the oil and air from mixing and creating foam. Foam affects performance because it can be compressed - fluid can not. With aeration reduced, the shock is able to react faster and more predictably, allowing for quicker response time and helping keep the tire firmly planted on the road surface.
http://www.monroe.com/tech_support/t...kabsorbers.aspLast edited by cocoy; November 17th, 2007 at 08:28 AM.
Tsikot Member Rank 3
- Oct 2006
- 1,069
November 17th, 2007 10:33 AM #6Koni sport adjustable shocks is the best suited for our road conditions. It will last the lifetime of your car.
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Jul 2003
- 573
November 24th, 2007 04:59 PM #9gas filled shocks are most suited for hiway and high speed driving condition.
it has a smmother ride than fluid types under this condition.
- Sep 2007
- 215
November 24th, 2007 09:17 PM #10old cars usually fluid type shocks ang nakakabit pero yung mga bagong models na car lahat almost gas type
usually we auto supplies recommend fluid sa harap then gas sa likod ...
pero mga cars ngayon gas type shocks na ang lumalabas kaya you have no choice but to change to gas type shocks
Weld preparation is poor. The WPS should have clearly specified what's to be done. Given that...
Chery returns to PH
