Results 1 to 8 of 8
- Jul 2005
- 61
November 16th, 2005 10:04 AM #1my car is a 7g galant ss a/t.
how can i eliminate that shift shock whenever its changing gears?
i need your advice badly. thanks.
November 16th, 2005 11:43 AM #2
i'm not sure if there is anything that can be done. current generation of a/t vehicles momentarily curtain power to unload the tranny so that smoother shifts can be achieved. what i do when i drive an a/t is at the point where the tranny will shift, i ease up on the accelerator. there's less 'shock' to almost none if you get it right. with the same technique, you can also 'trick' the tranny into changing gear at your desired shift points. you just have to practice it though.
November 16th, 2005 12:15 PM #3
seednie: in most cases there shouldn't be any, try changing your ATF first, it might be overdue.
On a side note, gen6 and 7 AT galants are notorious for AT breakdowns around the world.
November 16th, 2005 12:33 PM #4
have your engine or tranny support check. worn engine/tranny support also coz vibration or shift shock
November 16th, 2005 03:47 PM #5Originally Posted by seednie
sir,
check the atf level. anything below or above the required level will result in shift shock
November 16th, 2005 04:07 PM #6Originally Posted by seednie
sir,
check the atf level. anything below or above the required level will result in shift shock or power loss
- Jul 2005
- 61
November 17th, 2005 03:45 PM #7thanks. i will try changing the atf. i will give you feedbacks if this persists.
btw.........what is the correct level of atf on the tranny?
November 19th, 2005 09:47 PM #8
seednie,
it has a level indicator located at the bottom end of the dip stick.
my estimate is around 3 liters of atf. try using dexron III.
also check the filter of the transmission. i am not sure if it is the disposable type or the reusable type. clean/replace the filter too.
