Results 1 to 10 of 50
February 15th, 2008 12:52 PM #1
Pano po ba tanggalin ito? Any preventive measures para di na magkaroon ng rust yung brakes ko? TIA
February 15th, 2008 01:21 PM #2
magkaka rust yan talaga unless you have it painted. pag di mo nagamit ng matagal magkaka rust siya. pero once you use it mawawala din yun.
February 15th, 2008 01:40 PM #4
Get disc that are cadmium plated they don't rust as much and as quickly. Otherwise just use the car and when you apply the brakes that will remove the rust.
February 15th, 2008 09:31 PM #6
Because the bare Iron loses one of its electrons in reaction to air and water. It then becomes Iron oxide.
February 16th, 2008 12:25 AM #7
madalas mangyari to pag maulan o kaya pag lumusong ka sa baha, pagpark mo sa bahay kinabukasan tadtad ng kalawang..
February 16th, 2008 12:29 AM #8
and it's just surface corrosion, it won't damage your rotors... Even high end cars have this issue, just step on the brakes while the car is running above 10kph and it's gone right away, ignore it.
i have a theory, if the oil filter is not primed (filed up prior to installation), the initial...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
