Results 11 to 18 of 18
- Oct 2007
- 120
January 9th, 2008 05:58 PM #11Niky, Here's an interesting article on run flats http://www.nytimes.com/2007/03/11/au...bjects/T/Tires
March 14th, 2022 12:09 PM #12
2022...
anyone here using Run Flats on their non-European daily driver?
- Sep 2021
- 901
March 14th, 2022 01:36 PM #13I've read through the previous comments (from 14 years ago).
All I can say is given the cost of these tires, para lang talaga ito sa mga cars of VIPs etc .(with armoring/bulletproofing) so they can continue driving for a certain distance & speed even if the tires are shot at.
Pero kung para maka iwas lang sa hassle na magpalit ng gulong & vulcanizing... nah.
I wonder if these tires can be vulcanized/repaired (will look it up nga- na curious tuloy).
BTW, I know may mas practical variation din for general public use din ata ito dati (like 2 thinner tires on a special rim- may billboard nito sa E Rod. between Gilmore & Hemady) but it never became mainstream. Baka sobra mahal.
Extra aquaplaning resistant din daw because of the deep channel between the twin tires...
March 14th, 2022 01:39 PM #14
- Sep 2021
- 901
March 14th, 2022 01:44 PM #15
March 14th, 2022 02:20 PM #16
March 14th, 2022 02:31 PM #17
What Egan101 said. Expensive. Matagtag pa. The reinforced sidewalls have little to no give compared to normal tires. You'll also need to have a TPMS installed so you don't go around wrecking the tire by going over the speed/range limit when it is flat. Di kasi masyado ramdam sa RFT kung flat na. Finding a replacement is also hard as most importers only keep a few in stock. Madalas walang stock.
Luxury cars need to have these because they have removed the spare to make way for extra storage space.Last edited by Wh1stl3r; March 14th, 2022 at 02:40 PM.
March 14th, 2022 03:12 PM #18
I actually saw this vlog kaya bigla kong naisip kung normal na ba run flats...
I use imgur.com. Upload the picture there, then get share links, choose bbcode and paste here.
Mineral , semi synthetic or fully synthetic?
