Results 1 to 10 of 11
March 11th, 2010 06:55 PM #1
It'll depend on why it's rubbing. If it's rubbing because it's too wide, it'll help a little... but if it's rubbing because it's too low, it'll help a lot. Rolling the fender is a more complete solution.
I had to do both with my car. Mags were too wide and car was too low.
- Mar 2010
- 19
March 11th, 2010 07:03 PM #2thanks guys. its rubbing bcoz its too low i think... ill go with the spacer first then drive
if i need more, fender rolling is next... thanks
appreciate more inputs
March 11th, 2010 07:53 PM #3
You can have the spacers fabricated at Cruven for about 300-400/ pc depending on the thickness you need.
- Mar 2010
- 19
March 11th, 2010 07:58 PM #4speaking of thickness... what's the maximum height that is advisable to use for spacer? 2, 3, 5, etc inches?
is there sort of efficient limit?
March 11th, 2010 08:50 PM #5
It actually depends on what you will be needing to solve the rubbing. As for me, I'm using 1.5" for the front and 3" for the rear for a Nissan X-trail which is quite high. Maybe an inch or 1.5" would solve your problem. Anyway, you can ask them to measure it for you. Hope this helps! Goodluck!
- Mar 2010
- 19
March 12th, 2010 07:23 PM #6
March 12th, 2010 07:53 PM #7
where did you end up having the lifters fabricated and how much did those set you back?
So it's another case of "pwede na iyan" once again. It's that kind of thinking that will put...
