Page 1 of 2 12 LastLast
Results 1 to 20 of 40
    guys tanong lang, may nabibili bang rubber lifter para sa coil springs na 1" lang? ung nabili ko kasi 1.5" ata tapos ung sumunod na manipis sobra na nipis. ok kaya kung bawasan ko na lang ung lifter? cut ko na lang....lalagay ko kasi sa harap ung mas manipis tapos ung makapal sa likod. for 98 civic nga pala. thanks
    meron. usually sa mga auto supply meron. try mo sa wally's west along west ave.
    Nov 2003
    pass by the shop. we should have the one inch lifters.
    thanks sa mga reply.
    *speedy meron din kayo .5 inch? im not sure if 1.5 inch nga ung nasaakin eh. sukatin ko nga maya pag uwi. magkano din pala pakabit?
    thanks.
    Nov 2003
    normally meron naman kami.
    thanks speedy
    OT na konti. the reason kaya ako maglalagay ng lifter kasi sobra ung drop nung lowering springs. mas ok kaya ung lifter o bumili na lang ako ng adjustable springs...
    thanks.
    Nov 2003
    lifters will be cheaper.
    meron din nman adjustable na lifter dba?yung bakal na may ksama goma, tapos may bolt na pde i adjust kung mataas o mababa.
    Nov 2003
    haven't seen anything like that yet...
  10. #10
    may nakakalat ako ditong rubber lifter, mga 1 inch po, di ko pa nagagamit, kasi di kasya sa liteace ko,e... PM nalang ako kung may nakakagusto..
    share ko lang...
    Feb 2005
    HELP: Do rubber lifters work by pairs? I mean, you need a pair installed per spring? or okay lang isa..
    i just hope tama intindi ko sa lifter.. yung gomang itim na nakalagay sa pagitan ng ikot ng spring.
    Feb 2005
    picture added.. lifter ba tawag diyan? pwede bang isa lang nakakabit? TIA
    Feb 2005
    help naman po..
    Quote Originally Posted by cocoy_01 View Post
    The typical "lifter" you will find locally would the be "donut" kinda of lifter where it is installed between the spring and spring seat.
    Aug 2004
    Mas maganda ang donut (as long as it ain't too thick)...
    Feb 2005
    Thanks guys! May i know what is that thing attached to my springs?
    Where could i get lifters? What's the thickest size available? How much would it typically cost?
    Feb 2007
    try mo kay m7 in san juan or banawe. customized yung pagawa ng rubbers doon, susukatan mismo yung suspension mo. look for ritchie
    Sep 2005
    check ko lang, baka may marecommend kayo na shop na nag-install ng rubber lifters.
    M7 at cruven lang ba talaga? pls update na rin yung recent pricing and experiences sa kanila
    tnx
    May 2008
    Kanina lang nasa curven ako sa cubao..nagpalagay ng rubber lifter para sa rear spring ng kia carens..maganda yung pagkaka gawa nila ng rubber lifter, malinis at sakto sa sukat..
    2" yung lift na pinalagay ko and inabot lahat ng 1,400..
    per inch kasi yung presyo sa lifter..
    wala pang 3 oras tapos na trabaho nila..galing nila dun..
    Sep 2005
    Quote Originally Posted by ronaldlph View Post
    thanks ronald
    so P1400 para sa 2pcs ng lifter. I assume kasama na labor, pero parang ang mahal pa rin. magkano kaya kapag 1inch lang (2pcs)?
rubber lifter
