Results 1 to 7 of 7
    Has anyone used the R Spec Cross Drilled Rotors on their cars? They are quite cheap but it seemed they are a bit thinner as compared with the oem's? Tatagal kay ito for my daily driven Pajero?
    TIA!
    Quote Originally Posted by blue View Post
    TIA!
    Saan mo nakita sir and how much?
    For the rspec brake pads, from experience, it's noisy.
    You might also consider Joseph atutubo. Alam ko gumagawa siya ng cross drilled for the pajero.
    i just saw it in sulit kanina, inquired but di pa sila reply how much and if avail sa fm. post ko dito if my response na sila.
    Dec 2007
    Sorry to burst anyone's bubble but cross-drilled rotors are usually a bad idea. That's just another area where you can introduce fatigue into the rotor and wreck your braking capability.
    Couple that with the R-Spec brand name and I would advise you to walk away.
    May 2010
    what you really need are really good sport brake pads
    thanks for the heads up info sirs!
    Aug 2004
    Quote Originally Posted by Type 100 View Post
    Echo that. Freaking scary to experience green fade on brand new pads just twenty minutes after installing them while going a relatively sane 90 kmh on the highway. Avoid any brake product from R-Spec like the PLAGUE.
