Results 1 to 10 of 10
- Jun 2005
- 73
August 13th, 2005 04:45 AM #1kailangan bang gawin ito? nakalagay kasi sa PM Guide, every 40K Km. saang shop ok magpaservice? preferably Q.C. area.
August 13th, 2005 08:15 AM #2
sir, ano ang car mo? would you believe yung car ko (civic 96), ever since hindi pa napapalitan? i already got 144K kms on the clock.
August 13th, 2005 09:08 AM #3Originally Posted by Engr
i just had my 40K PMS done and the casa drained all the old power steering fluid and replaced with new power steering fluid
August 13th, 2005 10:17 AM #4Originally Posted by ian_rex
- Mar 2005
- 354
August 13th, 2005 10:24 AM #5klangan b tlaga palitan ung fluid? kc ung sentra ko, nung naubusan ng fluid eh bumili lng ako sa mga shop ng power steering fluid. tapos ako n mismo naglagay. Ok nmn. 90petot lng ata un...
August 13th, 2005 10:43 AM #6Originally Posted by raine
if it ain't broke or specified on the owners' manual, don't replace it.
August 13th, 2005 11:10 AM #7
dali lang i-DIY yan. drain mo lang tapos fill up with new fluid. make sure you run the engine afterwards and turn the steering wheel back and forth, then check again the fluid level. you may have to do this several times to completely bleed the system.
Tsikot Member Rank 5
- Nov 2003
- 3,849
August 13th, 2005 09:55 PM #8by draining just the reservoir you don't get the psf in the rack itself. disconnect the return line, start the car for a couple of seconds and the the ps pump should pump out the remaining psf. don't run it for too long or the pump will run dry.
August 25th, 2009 02:49 AM #9
August 25th, 2009 08:17 AM #10
Like engine oil, PSF needs to be replaced as recommended in the manual because the additive package gets used up in time. Once used up, the PSF may lose some of its protective properties and can potentially lead to pump or steering rack problems later. Replacing the PSF is relatively cheap, compared to replacing any of the steering components.
To replace the PSF:
Before beginning, it's best to have both front wheels jacked up. Remove as much PSF as you can from the reservoir using a large syringe or a tool similar to a turkey baster. Detach the return hose from the reservoir and insert it into the mouth of a suitable container. Have rags on standby at the mouth of the container as the pressure from the power steering pump (once you start the engine on the next step) has a potential of spilling PSF on you or the engine bay. Have someone start the car and rotate the steering wheel stop to stop. Once all of the old fluid has been expelled into the container, return the steering wheel to center and turn off the engine. Reattach the return hose onto the reservoir and pour in the new PSF up to the MAX level. Start the car again and rotate the steering wheel lock to lock while new PSF is being poured down the reservoir, always keeping the level at MAX. Keep rotating the steering wheel to bleed the system and stop only until the PSF inside the reservoir becomes consistently level. Cover it up and you're done. Check the PSF level again after a day of driving to make sure it's at the proper level and there's no leak in the system.
My last piece of advice; always put in the proper PSF type for your car. There are a few aftermarket PSF for sale in hardware stores but it is my opinion that the OEM kind will be the best choice, for the sake of compatibility.
