Results 1 to 10 of 24
May 2nd, 2008 11:24 AM #1
nagpalit po ako ng 15's mags and 1 set ng eagle ventura tires. Bagong align at tire balance and camber din po ung front and rear tires ko kahapon. Kanina nung nasa skyway ako ang lakas ng vibration ng manibela and ung buong car pag 80kph to 120kph na ung takbo. Nung nagpa balance naman ako ng gulong 0/0 naman ang lumalabas..
feeling ko ung mags ung may sira, nabili ko po ung mags dito ng 2nd hand. Pano po ba malalaman kung may sira ung mags?
May 2nd, 2008 12:25 PM #2
Get the tires rebalance as a weight has shifted or one has fallen off on the inside of the wheel. Either way they will find out the problem. Is this problem happened before you change the wheel?
- Jul 2003
- 573
May 2nd, 2008 12:40 PM #3bring it back to where you have bought the rims and tires to make sure that they are properly balanced. If you still have the same problem afterwards, try another shop to check and balance the wheel. It could be the guy or the balancing equipment is at fault.
May 2nd, 2008 12:51 PM #4
naku 2nd hand lang kasi ung rims, ung 4 na goma lang ung bago..
May 2nd, 2008 12:54 PM #5
sir the wheel balance is only for low speeds. yung tipong 40kph wiggle ka na. the rims is also not the problem here kasi dapat simulat sapul wiggle ka na din... there might be something wrong with your suspension, try looking at the tie rods, usually dun nanggagaling yung vibrations at high speeds.
also did you change the bolts? lug-nuts maybe?
- Jul 2003
- 573
May 2nd, 2008 01:03 PM #6if I understand it correctly, the vibration occured only after the rims and tires were changed. So I still don't discount the possibilities of the culprit coming from the new set of tires and the rims. The wheel maybe balanced correctly, but have you checked for side plays while turning the wheel? As in 'ocho'?
May 2nd, 2008 01:28 PM #7there might be something wrong with your suspension, try looking at the tie rods
thanks for the replies!!
May 2nd, 2008 02:04 PM #8
sir what kind of bolts did you put in? from what i know, the cheap once will make your wheels wiggle. just dont know if thats your culprit.
is the end of the lug-nuts parang patusok? if yes, maybe you found the prob. yung sakin kasi i bought the cheapos na patusok yung dulo and wiggle ako sa 120kph pero changed it to flat, nawala yung vibration.
May 2nd, 2008 02:11 PM #9sir what kind of bolts did you put in? from what i know, the cheap once will make your wheels wiggle. just dont know if thats your culprit.
May 2nd, 2008 02:16 PM #10
sir tangalin niyo yung isang nut, tignan niyo kung patusok yung porma... yung akin bili ko 800 dati, pero change to flat na 3k ata yung set of 16 nawala yung vibration at high speeds.
i confess, my seagull review is from internet literature. that so-called aircon issue is a...
BYD Seagull
