Results 1 to 20 of 24
    Mar 2005
    nagpalit po ako ng 15's mags and 1 set ng eagle ventura tires. Bagong align at tire balance and camber din po ung front and rear tires ko kahapon. Kanina nung nasa skyway ako ang lakas ng vibration ng manibela and ung buong car pag 80kph to 120kph na ung takbo. Nung nagpa balance naman ako ng gulong 0/0 naman ang lumalabas..
    feeling ko ung mags ung may sira, nabili ko po ung mags dito ng 2nd hand. Pano po ba malalaman kung may sira ung mags?
    May 2007
    Get the tires rebalance as a weight has shifted or one has fallen off on the inside of the wheel. Either way they will find out the problem. Is this problem happened before you change the wheel?
    Jul 2003
    bring it back to where you have bought the rims and tires to make sure that they are properly balanced. If you still have the same problem afterwards, try another shop to check and balance the wheel. It could be the guy or the balancing equipment is at fault.
    Mar 2005
    naku 2nd hand lang kasi ung rims, ung 4 na goma lang ung bago..
    wala po ako problem sa vibration before, nung stock pa ung rim and tires ko.
    sir the wheel balance is only for low speeds. yung tipong 40kph wiggle ka na. the rims is also not the problem here kasi dapat simulat sapul wiggle ka na din... there might be something wrong with your suspension, try looking at the tie rods, usually dun nanggagaling yung vibrations at high speeds.
    also did you change the bolts? lug-nuts maybe?
    Jul 2003
    if I understand it correctly, the vibration occured only after the rims and tires were changed. So I still don't discount the possibilities of the culprit coming from the new set of tires and the rims. The wheel maybe balanced correctly, but have you checked for side plays while turning the wheel? As in 'ocho'?
    Mar 2005
    just changed them all 6 months ago, tie rod, ball joint, cv joint, front and rear shocks.
    Yup kelagan ng separate na adaptor for the lugnuts..
    Yes, Wala po problem dati.
    sir di ko po ma gets to?
    thanks for the replies!!
excessive vibration at 80 kph and above
