Results 1 to 10 of 11
January 10th, 2014 12:15 AM #1
4 months na po yung tsikot namin simula namin nbili na 2nd hand. Napansin ko lang po ngayon na hindi pala pantay yung pagka pudpud ng gulong sa likoran. Nalaman ko ito nung ibyenahe ko sa malayo kasi maingay pag nasa espalto. Kailangan ba ito e alignment?
Posted via Tsikot Mobile App
January 10th, 2014 12:17 AM #2
January 10th, 2014 12:23 AM #3
January 10th, 2014 12:27 AM #4
Hindi kaya nilipat ng dating owner yung tire from front to rear. Dba front lang naman yung e alignment?
January 10th, 2014 12:29 AM #5
sir not sure with Isuzu Trooper, pero sa kotse alam ko may alignment din ang likod ng civic, altis,.
pero as far as i know, yun ganayang kalaki na vehicle may adjustment din alignment sa likod. wait tayo feedback ng expert sa isuzu trooper Sir. sorry po di ako makapaginput.
January 10th, 2014 02:56 AM #6
Can you describe how the wear is not even?
Hindi pantay ang kanan at kaliwa?
Hindi pantay ang loob at labas ng tire?
If it's the first, it might be the tires themselves, or you could have a busted shock which is putting more stress and causing more wear on one tire.
Or if the wear on the tire itself is unusual, it could be an alignment problem.
If both tires are worn on the outside, then those tires came from the front and were rotated back. Nothing unusual. If both are worn on the inside, then you should check the alignment.
January 10th, 2014 11:10 AM #7
Both tire are worn outside. Ok lang ba ito e byahe ng malayo?
Sent from Tsikot Car Forums mobile app
January 10th, 2014 12:33 PM #9
kung hindi independent suspension ang likod, mostly axle type walang alignment needed...
pero kung IFS ang likod its could be aligned...
if im not mistaken trooper is coil harap at likod and solid axle and likod, so no need na align likod.
correct tire pressure mo muna sir...
tama comments sa taas, pwede galing yan sa harap nilipat sa likod...
if you want definitive answers and peace of mind pa check mo alignment sa shops...
January 10th, 2014 12:38 PM #10
Thank you mga sir sa mga inputs.
Nagmahal na talaga but MMPC compensated naman the feature due to the following upgraded items: 1....
2014 mitsubishi montero
