Results 1 to 10 of 10
January 20th, 2009 10:46 AM #1
to all guru
i have a new problem with my car (nissan sentra b13)
just finish fixing the following
- Renew Steering Rack
-Renew Motor suport
-Convert motor support
- Camber alignment
now after fixing it i just notice when turning (full) to the right there is a little bit short in angle..
kasi sa lugar namin pag pauwi merong sharp curve na makukuha ng isang full turn ngayon hindi na kaya kailangang umatras ng kaunti para makapasok
any idea what's the culprit?
ipunta ko pa lang ulit this weekend sa shop na pinagpaayusan ko
TIA
- Sep 2007
- 174
January 20th, 2009 09:15 PM #2
Ganyan din sa akin. After changing the ball joints and other joints pertaining to steering and after the wheel alignment, parang nagkulang sa turning of the wheel. Yund dati na madali kong ikutin, ngayun hindi na puede. Aatras pa ako and maneuver the wheel. Hindi ko pa rin nabalik sa talyer. Let's ask our fellow tsikoteers.
January 22nd, 2009 09:16 AM #4
sir naka off center po ba yung steering nyo? pag straight ahead yung takbo?
January 22nd, 2009 11:29 AM #5
January 22nd, 2009 11:39 AM #6
January 22nd, 2009 08:11 PM #8
January 23rd, 2009 10:05 AM #9
- Sep 2007
- 174
January 31st, 2009 07:09 AM #10Naibalik ko sa repair shop kahapon ang L200.
The mechanic made adjustments on the pitman arm. Ito ung part na pag turn mo ng steering wheel ay parang lever na itinutulak ang left or right wheel to the direction you want to go.
After the adjustment, there was no improvement but we noticed ne hindi ma fully turn and wheel as we look while the pikup was raised.
He asked for the old pitman arm that I had replaced with the new one. His theory was that the new pitman was shorter so kukulangin and movement to the left or right.
Since hindi ko dala, we were not able to find out kung yung pinalit na pitman arm ang culprit.
high idle RPM at engine start
