Results 11 to 20 of 21
January 29th, 2009 02:49 AM #11
pag nasira ng todo ang PS pump mo mag seize an bearing kaya mag slip ang belt resulting in no ps and a cut belt. baka may madamay pa pag naputol ang ps belt.
January 29th, 2009 10:13 AM #12
ah sir titigas o bibigat ba ang manibela pag talgang sira na ang steering pump?
- Jan 2009
- 6
January 30th, 2009 06:14 PM #13ganun din yung na experience ko pag naka sagad sya left and right humuhuni din pinatignan ko sa citimotors kanina sabi normal lang daw un . wag ko na lang daw isagad..
- Nov 2008
- 51
Tsikot Member Rank 5
- Nov 2003
- 3,849
February 15th, 2009 12:43 PM #15most ps pumps can be overhauled with a simple kit. there are also bearings inside that need to be checked when overhauling. those bearings are not included in the repair kit.
- Feb 2008
- 577
February 16th, 2009 09:45 AM #16any idea where these bearing can be purchased? you're right repair kit only includes seals
February 20th, 2009 04:37 PM #17
may problem din ako sa power steering pump ng pajero ko. kagaya nung ke aga, may humuhuni pag lumiliko ng ng sagad, left or right. also, yung hi-ace namin, ang tigas ng manibela, parang walang power steering! pero hindi naman umiingay kasi may fluid naman nung tinignan. ano kaya mga problems ng ganito?
February 20th, 2009 08:34 PM #18
sir yung sa pregio ko ang may huni or kahit hindi sagad ang liko may konting huni ako naririnig kung talagang papakingan mabuti sir testa sabi ng mechanic ko tagas daw sa oil seal o o-ring ba yun kasi sabi nila konting tagas lang daw kahit katiting iingay daw talaga? but hindi ko pa nakikita ang steerig fluid ng van kung ubos na hirap kasi tingnan eh any update dyan sir medyo me kamahalan din kasi mag palit ng assembly repair kit o mismo power steering pump eh
February 21st, 2009 04:36 PM #19
kasi, ganito... yung sa kin din, humuhuni ang pajero ko. tapos may napansin ako sa ilalim ng gearbox, may maliit na tulo. duda ko o-ring yun bumigay pero ang ikinatuwa ko lang, hindi malakas ang tulo. tingin ko sir aga, o-ring din yang sa yo. monitor mo ang ps fluid mo. punuin mo tapos gamitin mo, then check yung level. pag nabawasan kahit konti, may tagas ang ps system mo, pero sa malamang yan, nasa gearbox, mga o-ring ang bumigay
- Jul 2008
- 32
March 22nd, 2009 02:45 AM #20as you said sir pag patay aircon mo wala kang naririnig na huni o ugong try to open your hood naka OFF ang Aircon then buhayin mo pag may umingay sa compressor yan ng aircon ang mga bearing dyan may tama na parepair mo kay mang mario dito sa thread ng tsikot under Airconditioning section change belt ka na rin ng compressor.
UK, Oz-wide JB74 fuel pump recall. Check Suzuki Ph for VINs affected. Sent from my SM-S901E...
Suzuki JIMNY [merged threads]
