Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Jan 2009
    Whenever I start the engine, I hear a whirring noise and the mechanic said that there is something wrong with the bearing in the power steering pump. They told me that it has to be replaced and they said that a surplus will do since the original is too expensive. And that the fuel pump can't just be fixed because once you open it, matatanggal daw mga O-ring and the fluid inside.
    Surplus - 5.5k
    Original - 23.7k
    Now i don't have the budget to replace it with an orignal. Do you guys think worth it palitan ng surplus? Or is there any other fix for this?
    Personally I dont have anything against surplus parts as long as it can be tested and returned if found "defective" within a few days or weeks.
    For vital parts – I prefer OEM for less worries and high risk of back jobs, best thing to do is compare the casa price to those that carry Honda OEMs outside. Good luck
    YABU, baka gusto mo palitan na lang ng surplus na p/s pump. Pareho ng kotse ko maingay din ang p/s pump,may tama na pala yung loob esp yun bearing, sa evangelista napapalitan ko 2k lng k n ngayon p/s ko.
    Jan 2009
    I consulted honda q. ave and sabi nila meron naman pala silang repair kit nito. so try ko muna paayos sa kanila before replacing it. mga 3.5k lang damage. so try ko muna siguro yun.
    i'd go for the repair kit path.
    have you chnaged your fluid? if you did, was it bled properly? improperly bled ps system can cause noise.
    Jan 2009
    I haven't changed it but i added some kasi mejo bawas na. I'm not sure if it was bled. Well i already left may car at honda q. ave. hopefully they can fix it and d ganun kalaki yung damage.
    Nov 2007
    mga sir add ko din pag lumiliko ang van ko right or left meron ako naririnig na sound na humuhuni steering pump din ba yun? check ko din ang level ng steering oil ayos naman?
    AGA, same din ng p/s ko before ko palitan ng surplus. humuhuni pag sagad left or right then nagkaroon ng whinning sound na naririnig ko din sa loob ng oto kht ilakas ko pa volume ng stereo, annoyed na ko sa tunog nya at kht pina repair ko for 2.5k saglitlang bumalik na ulit sa dati kaya nagdecide na ko maghanap sa evangelista,luckily nkahanap me ng mura 2k na surplus at sila n din nagkabit. marami ko napagtanungan nag start sa 4.5k then meron 3.5 etc pro un na ang pinakamura kaya ok na p/s ko ngayon, i'll give u his # kung gusto mo. peace.
    Nov 2007
    sige sir ano number nya? btw my ride is kia pregio meron kaya silang piyesa para dun? pero pag naka off ang aircon ng van wala ako naririnig na humuhuni?kahit full turn right and left
    mga pafs tanong ulit pag ba sirang sira na ang power steering pump delikado ba ito o maingay lang?
    pag nasira ng todo ang PS pump mo mag seize an bearing kaya mag slip ang belt resulting in no ps and a cut belt. baka may madamay pa pag naputol ang ps belt.
    Nov 2007
    ah sir titigas o bibigat ba ang manibela pag talgang sira na ang steering pump?
    Jan 2009
    ganun din yung na experience ko pag naka sagad sya left and right humuhuni din pinatignan ko sa citimotors kanina sabi normal lang daw un . wag ko na lang daw isagad..
    Sir Yabu,e2 # 09217398775 look for Rey. 1731 evangelista st,mkt.
    Nov 2003
    most ps pumps can be overhauled with a simple kit. there are also bearings inside that need to be checked when overhauling. those bearings are not included in the repair kit.
    any idea where these bearing can be purchased? you're right repair kit only includes seals
    may problem din ako sa power steering pump ng pajero ko. kagaya nung ke aga, may humuhuni pag lumiliko ng ng sagad, left or right. also, yung hi-ace namin, ang tigas ng manibela, parang walang power steering! pero hindi naman umiingay kasi may fluid naman nung tinignan. ano kaya mga problems ng ganito?
    Nov 2007
    sir yung sa pregio ko ang may huni or kahit hindi sagad ang liko may konting huni ako naririnig kung talagang papakingan mabuti sir testa sabi ng mechanic ko tagas daw sa oil seal o o-ring ba yun kasi sabi nila konting tagas lang daw kahit katiting iingay daw talaga? but hindi ko pa nakikita ang steerig fluid ng van kung ubos na hirap kasi tingnan eh any update dyan sir medyo me kamahalan din kasi mag palit ng assembly repair kit o mismo power steering pump eh
    kasi, ganito... yung sa kin din, humuhuni ang pajero ko. tapos may napansin ako sa ilalim ng gearbox, may maliit na tulo. duda ko o-ring yun bumigay pero ang ikinatuwa ko lang, hindi malakas ang tulo. tingin ko sir aga, o-ring din yang sa yo. monitor mo ang ps fluid mo. punuin mo tapos gamitin mo, then check yung level. pag nabawasan kahit konti, may tagas ang ps system mo, pero sa malamang yan, nasa gearbox, mga o-ring ang bumigay
    Quote Originally Posted by aga_cruz View Post
    as you said sir pag patay aircon mo wala kang naririnig na huni o ugong try to open your hood naka OFF ang Aircon then buhayin mo pag may umingay sa compressor yan ng aircon ang mga bearing dyan may tama na parepair mo kay mang mario dito sa thread ng tsikot under Airconditioning section change belt ka na rin ng compressor.
Problem with power steering pump
