Originally Posted by
jick.cejoco
your "mechanic" might have used other than honda/acura compatible power steering fluid. he might not have bled the system too. to bleed the system, unload the front tires (off the ground). while supported by jackstands, steer right to left without having to the extreme right or extreme left, you can hear the pressure relief valve when you have reached extreme, repeat procedure until the noise is gone. watch out for foaming in the reservoir too. if there is foaming, rest the system until the p/s fluid is clear.
