Originally Posted by
afrasay
heavy and humming in the steering happens when:
1. you have low/no ps fluid. this can be solve by just adding fluid and checking the
level in your dipstick.
2. air in the system. bleeding the system eliminates the air. if you don't have a bleed
screw just loosen the tubing (out) until only solid fluid spurts out from it. do this
with the engine running and while turning the steering wheel from left to right.
3. (heavy) underinflated tires.
A steering damper helps reduce shocks and jerks transmitted to the steering wheel when hitting potholes or ruts. It also makes the steering return to center. When wornout ,it will not contribute to heavy steering (unless stuckup yun cylinder) as it would make the steering more loose because of the absence of the damping effect. It's ok to drive without it, though a simple gutter and wrong hand placement combination on the steering wheel could give you a fracture wrist.
Though I'm not familiar with the Fuego's steering system I would suggest that you check the U-joints of your steering rods (the long rod that comes out of your firewall). Dalawa malamang ito. One near the firewall and one on the other end near the gearbox. Check for free play. movement should be smooth without sabit.
IMO, the mechanic should've replace only the steering repair kit (seals, o-rings, copper washers). The ball bearings in the worn gear seldom breaksdown and would normally outlive the life of the car. Adjust the steering play screw to minimize play and increase steering response. HTH.
