Results 1 to 7 of 7
April 1st, 2008 01:52 PM #1
I've noticed that when power steering is engaged, the idle goes down to 500. This happens when the steering wheel is at it's peek either if it's to the left or to the right. Bagsak nalang siya bigla, tapos ayun balik normal idle. Is this a problem or what?
If you're going to ask if the A/C , lights and sounds are on, it really does not matter because it also happens when these things are off.
Thanks for the advice.
April 1st, 2008 02:14 PM #2
hmmm... the RPM should fluctuate if the steering pump is working (steering wheel is in full turn). Kung bumabalik naman sa tamang idle speed then that's nothing to worry about.
But 500 RPM sounds kinda low to me.
- Jan 2008
- 4,726
April 1st, 2008 06:37 PM #4that is normal when you fully turn the steering wheel at peak on either side because the power steering pump gives pressure on the power steering. when it reaches maximum steer at its peak and you HOLD the steering wheel in that position, the power steering pump senses that you still need the assist thus giving more pressure causing your idling to drop, there is no where the pressure will go thus the pump will give more pressure on the power steering that in turn may cause high pressure build-up and may damage prematurely your power steering fittings and hoses.
if you will read your users manual, there is an instruction there saying that you should not turn the steering wheel at its "MAXIMUM" to avoid damaging the power steering pump.. when you make a full turn and the steering reached its maximum, you should turn the wheel back a little to avoid damaging the power steering pump
April 1st, 2008 07:19 PM #5
April 2nd, 2008 01:15 AM #6
If it's not that expensive, pagawa mo na lang just watch over the repair. Easier accomplished as a two man job.
Some cars had power steering filters, some don't. Check yours for any to be on the safe side.
Xiaomi E-Car
