Good day! Pips, i just want to ask magkano magagastos kung ipa power steering ung car? Honda Civic Lxi 92 po ung car ko...thanks in advance!
rough estimate nung napagtanungan kong mechanic is between 9K- 14K. Pero I believe mataas na yung 14K.
Up ko lang. Asking this for a friend...
San pwede pa convert to power steering for a 99 Honda City?
Around how much na rin?
Thanks
if you want to convert, it will cost around 20k-25k....
teka teka, city hindi pa power steering? ang alam ko power steering na yan.
hi guys,
just want to inquire about wheel alignment, camber and steering...
i recently inquired at an alignment shop in banawe re wiggle sa likod ng kotse ko. they told me to replace lower arm bushing and trailing arm bushing. i went to my suking mekaniko and had it fixed yesterday. when i went back to have it aligned after replacing the parts, the alignment shop told me that the car needs to be cambered, front 750 and rear 550. are the rates ok? before kasi i went to servitek pero ngayon sa banawe na lang. malayo na kse sa place namin servitek.
thanks for your help!
ok lang. pag nagpalit ng parts sa suspension and steering need (not a must) mo magpa align/camber. this is to keep the steering and suspension geometry intact. Di kaya may bulge yun rear tire mo kaya may wiggle ka?
thanks afrasay. nope nag check din kami sa tires sa harap at likod ok naman. nakita talaga na trailing arm bushing yung gumagalaw at maluwag. nagpalit din ako stabilizer link, dalawa. pag na pa align at camber maayos din ba steering? parang sumobra kasi yung ikot ng manibela pag lumiliko. instead na 90 or 180 degrees both clockwise and counter, lumalagpas pa
thanks ulit
What do you mean, di pareho ang turns niya sa left and right? pa adjust sa steering rod to the gearbox to have equal or almost equal number of turns.
ano mas mabigat assuming exactly the same car, same rims, same tires, as in exactly the same
- rwd pawis steering
- fwd pawis steering
paano nila ica camber harap mo? wala naman adjustment sa harap unless initin mo yung arm or bibili ka ng camber kit.
