Results 1 to 14 of 14
    Jul 2006
    Good day! Pips, i just want to ask magkano magagastos kung ipa power steering ung car? Honda Civic Lxi 92 po ung car ko...thanks in advance!
    rough estimate nung napagtanungan kong mechanic is between 9K- 14K. Pero I believe mataas na yung 14K.
    Jan 2008
    Up ko lang. Asking this for a friend...
    San pwede pa convert to power steering for a 99 Honda City?
    Around how much na rin?
    Thanks
    if you want to convert, it will cost around 20k-25k....
    teka teka, city hindi pa power steering? ang alam ko power steering na yan.
    Jan 2008
    i think its an LX model
    parang mahal. may nag-quote sa kanya 15k lang. nagca-canvass lang ako for a better deal.
    any recommended shops?
    thanks anyaway
    Quote Originally Posted by archie123456789 View Post
    Nov 2003
    babagal pa yan lalo because of the extra load of the ps pump.
    hi guys,
    just want to inquire about wheel alignment, camber and steering...
    i recently inquired at an alignment shop in banawe re wiggle sa likod ng kotse ko. they told me to replace lower arm bushing and trailing arm bushing. i went to my suking mekaniko and had it fixed yesterday. when i went back to have it aligned after replacing the parts, the alignment shop told me that the car needs to be cambered, front 750 and rear 550. are the rates ok? before kasi i went to servitek pero ngayon sa banawe na lang. malayo na kse sa place namin servitek.
    thanks for your help!
    ok lang. pag nagpalit ng parts sa suspension and steering need (not a must) mo magpa align/camber. this is to keep the steering and suspension geometry intact. Di kaya may bulge yun rear tire mo kaya may wiggle ka?
    Quote Originally Posted by afrasay View Post
    thanks afrasay. nope nag check din kami sa tires sa harap at likod ok naman. nakita talaga na trailing arm bushing yung gumagalaw at maluwag. nagpalit din ako stabilizer link, dalawa. pag na pa align at camber maayos din ba steering? parang sumobra kasi yung ikot ng manibela pag lumiliko. instead na 90 or 180 degrees both clockwise and counter, lumalagpas pa
    thanks ulit
    What do you mean, di pareho ang turns niya sa left and right? pa adjust sa steering rod to the gearbox to have equal or almost equal number of turns.
    Apr 2006
    sa 91 'rolla po kaya, magkano pa-power steering? tia.
    Quote Originally Posted by m2ponce View Post
    hi guys,
    imho, the prices quoted for the camber is standard.
    ano mas mabigat assuming exactly the same car, same rims, same tires, as in exactly the same
    - rwd pawis steering
    - fwd pawis steering
    Nov 2003
    paano nila ica camber harap mo? wala naman adjustment sa harap unless initin mo yung arm or bibili ka ng camber kit.
power steering
