Results 1 to 10 of 10
- Aug 2018
- 28
August 28th, 2018 03:08 PM #1As the thread is titled, are there any companies producing coilover systems in the Philippines at this moment.
Sent from my Flare S5 Plus using Tapatalk
August 30th, 2018 01:37 PM #2
- May 2018
- 611
August 30th, 2018 01:57 PM #3Can anyone enlighten me on the logic of putting coilover shocks in a sedan?
Dati kasi, coilover shocks were intended for use on vehicles carrying heavy loads. This would assist the springs on the suspension, prevent them from prematurely sagging, as well as help keep the rear tires in contact with the road.
I have them on my Hilux na lifted though I rarely haul heavy stuff, but I can't seem to find any reason why one would put this in a passenger car. Besides, they're very stiff since intended as additional support sa suspension, and they will give a very harsh ride.
I'm not ridiculing folks who do this (kotse nila yun eh, choice nila yun) but maybe bago na rin ba ang concept ng coilover shocks that I'm not aware of? I'm curious lang naman.
August 30th, 2018 02:10 PM #4
Short answer bro - yes, the coilovers you have in mind are different from the adjustable coilovers that modded cars have. Here's a primer:
Lowering Springs vs. Coilovers | What's the Difference In Cost & Performance?
People usually get coilovers to lower their car's ride height, but other adjustable settings include damper and rebound. Yes they are generally stiffer than stock springs, but if you're interested in getting better handling in the corners, the stiffer springs give you less body roll.
Most people only really want to lower their cars so lowering springs are good enough, but there's always that niche of people who burn money on mods they never fully utilize, hence the market for expensive coilovers even on cars that never see the track or even mountain roads.
August 30th, 2018 02:23 PM #5
a bit local car culture history in case you weren't aware
in the 90s to the 2000s the fad wasn't pickup trucks
the fad was honda civics and toyota/nissan/mitsu counterparts
it was the time of the first Fast and Furious movie
every "racer" wanted to lower their rides
there are 3 options
the cheapest -- putol stock spring -- which is stupid IMO
for those with some budget -- lowering springs (Eibach, H&R were the popular brands back then)
and rich kids are the ones who can afford coilovers among other performance parts
unlike lowering springs (not adjustable)
advantage of coilovers are adjustable ride height, damper, rebound settingsLast edited by uls; August 30th, 2018 at 02:26 PM.
August 30th, 2018 03:20 PM #6but I can't seem to find any reason why one would put this in a passenger car. Besides, they're very stiff since intended as additional support sa suspension, and they will give a very harsh ride.
August 30th, 2018 03:49 PM #7
funny how things have changed
from lowered cars...
now the fad is pickup trucks with big tires and suspension lift kits
ito ang pataasan ng ihi ngayon
so is it like the taller the truck the bigger the tires the more alpha the owner?
hahaLast edited by uls; August 30th, 2018 at 04:10 PM.
- May 2018
- 611
August 30th, 2018 05:16 PM #8For some I guess, kasi yun ang mindset nila. They try to overcompensate for their insecurities by buying huge vehicles, carrying firearms (when wala naman actual threat sa kanila), or putting all sorts of vanity plates ostenisbly showing their status- Prosecutor, Lawyer, PNPA, NBI etc...
- Feb 2014
- 2,536
August 30th, 2018 05:20 PM #9
suspension is complicated stuff. i play w/ mountain bike suspension all the time. you've got compression damping, rebound damping. spring rates. low-speed fluid circuits. high-speed circuits. some simple dampers have spiking issues on high-speed hits. etc etc
for your "supercar" you better just pick off the shelf stuff. no need to reinvent the wheel
August 30th, 2018 05:36 PM #10
yes it's complicated stuff
you can win or lose races due to suspension setting
you can have 2 identical cars with same engine power but with different suspension settings and one of them will have better lap time
Xiaomi E-Car
