Help! May steering problem pajero ko, there was "Tok" sound when i tried to manuever it, then tumigas na sya, hindi na sya makapag turn ng left or right. it all started when we changed the mag wheel with 16" mob rims, then they offer us free alignment and adjustment of steering dahil may play. then nagamit pa for 1 day yung pajero. the next day ayun na! tumunog na sya na parang may naputol or something. a mechanic checked the car and tried to fix it, and sabi nya possible na daw na power steering pump or gearbox. what do you think guys?
If any of you guys knows someone who specializes this particular problem please kindly post it here.
Any help from members who experienced the same problem will be appreciated. TIA!
please help. i tried to find and search for the same problem but most of the steering problem are just leak oil and "tok" sound problem. but mine is completely unusuable, i can only move the car forward and backward. my mechanic didn't show up today. and you know naman i cant bring the car to auto shop.
habol ko lang nakapag drive na ako ng pajero subic medyo mabigat din ang manibela pero ayus naman hindi ko lang alam kung anu yung nag B-BLINK sa dash board nya na apat na gulong minsan salitan minsan steady nu kaya yun?
thanks sa reply. according to my mechanic gearbox daw talaga yung sira. ask ko sya about idler amr & center post. yung sa tie rod naman im not sure din kasi wala naman ako nadadanan na malubak, city driving lang ako makati and pasay area lang. pinaka long drive na nya is yung from subic. mag 2 months palang sya samin, ngaun nagkasakit dahil ka cguro dun sa inadjust.
and as for the blinking in dashboard, baka yung indicator lang sya if naka 2/4 wheel drive ka? baka nagloloko lang cguro yung led? im not sure din kasi hndi ko rin nagagamit 4wd.
btw, na try pala namin ng nakalutang sya ayun lumambot na sya pero nung nkalapat na ulet matigas na.
parang steering box na nga sir.naka pag kanvas ka na ba kung magkano ang steering box? diba may pump o bomba ang steering sabi ng mekanik ko pag mahina na yun medyo matigas na ang manibela? sir it means talagang mas matigas pa sa hindi power steering ang manibela nyo as in parang naka simento? o parang nakapatay ang power steering nya?
ok naman yung pajero sir halos walang pinagkaiba sa local na pajero yun kulay nya lang at saka konting iba sa dash board at saka power seat ang local version
more or less 10k daw yung gearbox. working naman daw yung pump pati yung hose. (pinasirit namin oil). and yung steering nya mas matigas pa kesa sa manual steering.
ok naman sya before, swabe ang power steering at malambot. ok din ang loob at dashboard. color nya is green na parang blue. hehehe.
nakuha ko sya for 350k. then gumastos pa ako ng almost P100k, sa audio system, tint, tires and rims, tapos marami pa pinalitan.. pinakalast na sana yung rims and tires tapos saka bumigay!! badtrip talaga ako!
ayus lang yun sir pag may sasakyan ka parang anak mo din yun pero mabigat ang gear box 10k hindi birong gastos tapos labor pa, btw anu ba daw gear box o steering box???
sir na try nyo na ba mag inquire sa cruven? hirap kasi nyan pag pinalitan ang gear box or anu man yun gagastos ka ng 10k tapos hindi pala ayun ang sira? try ka muna mag 2nd opinion sa ibang mechanic wala ibang tsikoters baka nasa galaan kaya di makapag post.
ito nga pala number ng cruven sucat lapit lang ata ito sa sm sucat #8254874
sabi nya kasi is gearbox. wala kasi ako alam masyado sa sasakyan, actually 1st car ko itong pajero christmas gift ng dad ko.
parang duda nga rin ako sa mechanic eh, sabi kasi nung una pump lang, then tinanggal nya yung pump and tinest, ok naman daw. tapos ngaun gearbox na nga daw yata. pero hindi rin ganun ka sigurado kaya ayaw nya galawin.
hindi ko pa natry magtanong sa ibang mechanic, feeling ko kasi hindi rin nila masasabi til they saw it in actual. try ko tawagan cruven. sana pwede home service kasi hindi talaga pwede mailabas yung car. atras abante lang sya. hehehe.
wait ko rin yung ibang tsikoters. wait lang ako may magsabi kung ano talaga sira. yung tipong "ay! gearbox yan for sure. it happened to me b4" hehehe. yung mga tipong ganun. lolz!
antay ka lang sir tingin ko hindi pwede home service sa cruven kung may kilala kang humahatak na naka angat ang harap pahatak mo na lang pero 100%percent sir kayang kaya ng cruven yan
sir sabi nung owner sa amin ng pajero subic gear box daw ata yun kasi tinatamaan daw yun sa pag conversion ng pajero right hand to left, it means kung ayaw talaga ang sira napa tiyempo sayo , btw pwede pa ba tawagan yung pinagbilhan mo?
hmmm.... im not an expert pero AFAIK may provisions ang chassis ng pajero for left and right hand drive gearbox, same with the land cruiser. ang tatamaan lang talaga sa conversion nyan is yun body (provision for the pedals and steering wheel) and yun mga hoses ng aircon, power steering, and brakes. other than that wala na ko alam na tatamaan.
nun nilift nyo ba yun front at inikot yun manibela, gumalaw ba yun steering column? naililiko ba sya or hindi? kasi kung gearbox yan dapat stuck up na yun steering mor or may grinding sound kapag nililiko since puro bearings at bulitas ang laman nun.
Ang suspect ko eh yun power steering pump. instead na mag-assist sa pagsteer eh nagiging hindrance pa. para macheck mo, patanggal mo yun belt ng power steering tapos try mo magsteer. check nyo kung gagaan ng konti. baka kasi may bara yun hose or nasira yun pump
nung nilift namin ung front ok naman sya mag steer, malambot at swabe. so does it mean hindi gearbox ang sira? yung pump naman and hose triny namin pasiritin yung oil by steering left and right, nagpupump naman sya.
try ko patanngal yung belt and see what wiil happen. sana nga pump lang problem.
feeling ko kasi kaya nasira dahil nung pinadjust yung power steering nya, pnwersa kasi nung mechanic sa evanglista. gumamit sya ng wrench tapos tinodo pihit.
