Results 1 to 4 of 4
- Nov 2007
- 10
November 20th, 2007 01:24 PM #1Currently need to replace my tires with new ones, went to bridgestone earlier at the fort and found out that theres a 275/70R16 size with just a few hundreds difference from a 265?
Would it be advisable to use 275 than a 265? for use, looks etc?
Thanks
January 14th, 2012 10:27 AM #2
Negative. Stay with 265.
If you use the 275 you may have to change rims otherwise you are prone to a blow out.
Which may spell disaster motoring.
January 16th, 2012 10:57 AM #3
Go for 275s if you like. The increase is still quite small really to be of any real concern to performance and safety. Ask Bridegstone to test mount one tire so you can see how it comes out first.
We did the same on our Patrol GU before as the stock 265/70R16 tires were quite small (we could have even easily gone up to 285/70s with no problems).
January 16th, 2012 08:54 PM #4
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
