Results 1 to 10 of 10
- Jul 2010
- 21
October 18th, 2012 08:37 PM #1Guys need help po..alin sa dalawa ma recommend niyo for my ride..(2012 Toyota hilux 4x4)..TIA po
- Jul 2010
- 21
October 19th, 2012 12:42 PM #3
October 19th, 2012 12:55 PM #4
Bilstein. But pricey. Consider Rancho RS9000XL or IronMan Nitrogas shocks. Get 'em from 199ORH.
October 19th, 2012 05:26 PM #5
Bilstein will be a good choice then...mas mahal yata bilstein. But your almost new stock (likely KYB) should be good enough. If you're going to increase ride height, then maybe that's the time you change.
My 2007 hilux 4x4 had a 2" lift early this year...I used ironman 4x4 brand...nagustohan ko handling niya sa kurbada, ganda ng damping. OME is generally matagtag/mas matigas than bilstein (as per my friends observation on his hilux).
- Jul 2010
- 21
October 20th, 2012 08:16 PM #6
October 22nd, 2012 10:16 PM #7
Lift springs naman magdadala ng load not the shocks. Yung rebound ang sa shocks...your planned upgrade should be fine.
- Jan 2011
- 18
November 28th, 2012 05:21 PM #8
- Apr 2009
- 429
November 28th, 2012 11:52 PM #9rebuilt shocks don't last long. As for new shocks, Most Australian aftermarket suspension set are tuned as a set and perform best when used as a set. meaning you have to get the whole system (lift springs - coil or leaf, shocks, PU bushings, torsion bars, etc).Its just a matter of preference on how you will use your rig or what ride quality you prefer like comfort, constant load, etc. Putting an aftermarket shock (Australian or US-brand) to your stock suspension will not do much unless paired with its tuned set...
Bottomline, however, is ride quality is very subjective and preference differs from each person
- Jul 2010
- 21
December 6th, 2012 12:11 PM #10
https://www.youtube.com/watch?v=CEnGseEQxn0 Ford Territory Lemon Issue Debunked by Real Ryan.....
(2023) Ford Territory
