Results 1 to 10 of 14
October 2nd, 2003 09:25 AM #1
hi tsikot peeps, ano ba ang pros and cons ng mga nylon tires and steel belted?
nakabili kasi akong jaguar size 14" made in indonesia sya for P1350 only.. Nylon siya
- Mar 2003
- 12
October 2nd, 2003 01:21 PM #5ang problem lang with stell belted ay madalas sya makomang kapag underinflated or when it hits hard on uneven road...
October 2nd, 2003 02:45 PM #6
sabi ng erpats ko, ang nylon di gaya ng steel belt na pag natumbok ng bato nagkaka-bukol. ang steel belt nagbubukol, nylon hindi.
ewan ko lang ha, pero sa taxis ni erpats prefered nya ang nylon belted tyres, mas tumatagal kesa steel belted. and since yung mga taxi nya eh 18 hours on the road everyday at marami na syang steel belted at nylon belted tyres na nabili siguro naman valid yung conclusion nya.
but then again, tatay ko yun nagsabi kaya medyo ayaw ko maniwala e hehehehehe!
October 2nd, 2003 04:56 PM #7
I'll go for the steel belted tires. Mas ok ang handling. Lahat naman ng gulong na oblong pag under inflated o pag nalubak ng malakas.
October 3rd, 2003 01:10 AM #8Originally posted by yebo
Steel Belted:
The belt system's main function is to provide stability to the tread area of the tire, which contributes to wear, handling and traction. The most common belt material used is steel. Steel belts provide strength and stability to the tread area without adding a lot of weight to the tire. In steel-belted radial tires, belts made from steel are used to reinforce the area under the tread. These belts provide puncture resistance and help the tire stay flat so that it makes the best contact with the road.
nylon tires have nylon threads which, as a matter of fact, create more heat than the textile tires. When the car is in motion and the threads burn inside the tires, the threads become loose and the tires can burst.
October 3rd, 2003 10:17 AM #9
ngek akala ko mas malabo ang chance ng pagsabog ng tires if nylon ang tires mo
October 3rd, 2003 07:06 PM #10Originally posted by yebo
Getting a toyota would be ideal mostly for those looking for practicality or one who will use it...
China cars
