Results 1 to 8 of 8
March 23rd, 2006 09:48 PM #1
I found this advice while looking through the Tire Rack web site:
Breaking in Your Tires
Tires are comprised of many layers of rubber, steel and fabric. Due to these different components, your new tires require a "break-in" period to ensure that they deliver their normal ride quality and maximum performance. As tires are cured, a "release lubricant" is applied to prevent them from sticking in their mold. Some of the lubricant stays on the surface of your tires, reducing traction until it is worn away. Five hundred miles of easy acceleration, cornering and braking will allow the mold release lubricant to wear off, allowing the other tire components to begin working together. It is also important to note that your old tires probably had very little tread depth remaining when you felt it was time to replace them. As any autocrosser or racer who has tread rubber shaved off of his tires will tell you "low tread depth tires respond quicker." Don't be surprised if your new tires are a little slower to respond (even if you use the exact same tire as before). Their new, full depth brings with it a little more tread squirm until they wear down.
NOTE: Be careful whenever you explore the capabilities of your new tires. Remember that every tire requires a break-in period for optimum performance.
My questions are:
- Is there a maximum speed that should be observed when breaking in new tires?
- Does this mean I have to limit myself to short city drives until my new tires are past the break-in period? (Highway driving kasi, speeds reach 80 kph and over for extended periods of time)
- Does anybody in Tsikot actually follow these break-in procedures and, if not, has there been any adverse effect on the new tires' performance or life span?
- Jul 2004
- 167
March 25th, 2006 01:36 PM #2totoo ba yon na dapat me break-in period yong gulong. eh sa F1 race..pagkasalpak eh... tinatakbo na agad ng pagkabilis-bilis yong sasakyan hanggang sa palitan uli. For me it's a myth.
- Jun 2005
- 215
March 25th, 2006 02:25 PM #3Originally Posted by delprado
March 25th, 2006 04:39 PM #4
i've read that in a book before (way before the advent of net surfing) but i think the break in period is just 200 to 250 km.
what i remember:
keep speeds below 90 kmh for the first 100 km
it's ok to do the break-in in one sweep kaya ok lang for highway driving
i remember the book's title na. "Very Advanced Driving" from UK yun kaya mga lane merging and overtaking techniques nakakalito. right hand drive kasi eh!
March 26th, 2006 01:03 AM #5
Since we're in the Philippines, driving on the Aguinaldo Highway should surely break-in your tires haha.
March 26th, 2006 05:27 AM #6Originally Posted by delprado
AFAIK, ibang compound na gamit sa F1 tyres so no need for breaking-in. and kadalasan na pinapalit kapag nag-pits e gamit na rin na tyre.
March 26th, 2006 01:53 PM #7
sa tire dealer palang over inflate nila muna say 5 or 10 psi more than the recommended pressure. then you can lower it after a few hundred kilometers. that, i think would be enough for the tires to set properly on the rims. I would drive a brand new tire for more than 100kph after it has received a good drive (100km) or more around the city. this is not the "rule" but I just practice it.
March 26th, 2006 07:49 PM #8Originally Posted by delprado
Tire Break In
The ECSTA V700 does require break in. New tires will be slippery for their first laps, and will begin to feel better as they get scuffed in and build up heat. We recommend that drivers heat cycle their tires before using them in competition. Heat cycling helps you get the most consistent performance and tread life out of your tires. It is the process of gently bringing the tires up to temperature for a short duration and letting them cool. Ideally, you should break in your tires, remove them from your vehicle and set them aside for more than 24 hours before your track sessions and races. Often this requires running a practice session on new tires to prepare them for a future race, while you use tires prepared previously for the current race. The Tire Rack offers an automated heat cycling service that can complete this process before your tires are delivered to you.
I don't know why people continue to try and take Kennon Road from Rosario. Its perpetually being...
2023 Toyota Wigo
