Results 1 to 18 of 18
    guys, ano kaya problem, kapag kakabig ka sa kanan o kaliwa, may lumalagitik sa front. pero kapag straight naman walang problem. Tulong naman. thank you, reference [honda hatchback 92-95 model]
    bro, check mo power steering fluid mo kung may power steering ang eg hatch mo
    May 2004
    CV joint usually pag ganyan ang problema.
    guys replacement ba ang ginagawa kapag sira cv joints? mga magkano kaya magagastos?
    I'm no expert but I had the same problem before. Everytime I turn the steering wheel to the left I hear a tok tok tok sound in front. The tok tok sound disappeared after I had the CV joint replaced.
    May 2009
    This area was formerly labeled "The Workshop." We decided to rename it to better indicate its focus, which is still to provide words and music to allow you to sing all 150 Psalms
    The centerpiece of The Workshop is our metrical Psalters:
    (requires frames and is best with at least 800x600 resolution)
    We have the following metrical Psalters on this site. At present we have the complete contents of three of them. It is our intent to provide the complete contents of all of these Psalters, plus others as we have time.
    apostille
    Quote Originally Posted by apostilleus View Post
    apostille
    what???? spammer warning.
    :dry:
    TS you may also have the steering pump checked.
    apostille
    [SIZE=6]WARNING! SPAMMER![/SIZE]
    please no spamming.......
    BTT: I agree with JJ. have the steering pump checked.
    have the pump checked muna tapos update mo kami dito
    anyway [size=6]please no spamming[/size]
    bro ok naman ung pump, and ung atf di naman bumababa sa level niya.Ung rack end maari din ba problem sa concern ko? mga magkano kaya magagastos ko bro sa cv joint? and kung may problem sa rack end magkano rin kaya? thank you to all guys
    Nov 2007
    If the sound persist when the steering is being turned left or right, check you velocity joint, this is one symptom (lagatik sound) that it needs to be replaced.
    Apr 2009
    tsong.... 100% may sira yan c.v joint nyan... either sira ung outer c.v joint tripod bearing nya sa loob or yung inner sa c.v joint nya.check mu din ung shaft assy mu bka sira narin yung tred nya.... pagmagpapalit ka din ng c.v joint sure mu din mganda din yung mabili mung cv boots.. irerefer q sau din yung tokyo brand.. mdami din bumibli sakin nun na auto supply..
    yun lng masasabi q..
need help problem with steering [may lumalagitik kapag kakabig]
